Configure multiple SSL certificates for same IP address issue?
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Configure multiple SSL certificates for same IP address issue? Page: [1]
Configure multiple SSL certificates for same IP address... - 17.Apr.2013 7:29:44 AM
rahulbabarit
Hi All,
We have 3 SharePoint applications running on SharePoint server (IP: 10.3.4.1).
The two applications (one.domain.com & two.domain.com) are using a certificate targeted to *.domain.com. This certificate is configured on IIS server as well as it is bind to IP address 10.3.4.1 on ISA server 2006.
The third application (three.otherdomain.com) is using different certificate targeted at three.otherdomain.com. This certificate is configured on IIS server but unfortunately I cannot assign multiple certificates to same IP on ISA server 2006 since it is not possible (as per my understanding from google search).
Due to above issue I am getting the certificate error while trying to access the web application https://three.otherdomain.com.
The error is...
three.otherdomain.com uses an invalid security certificate.
The certificate is only valid for the following names:
*.domain.com , domain.com
(Error code: ssl_error_bad_cert_domain)
Please guide me on this issue. Will assigning multiple IP addresses to the same server help me?
Appreciate your help & support.
Rahul Babar
Rahul Babar
RE: Configure multiple SSL certificates for same IP add... - 18.Apr.2013 12:04:53 AM
rahulbabarit
I also found that all these 3 applications have same public IP. Can this be a problem?
Looking forward for the response.
Rahul Babar
Rahul Babar
(in reply to rahulbabarit)
RE: Configure multiple SSL certificates for same IP add... - 10.May2013 6:36:29 AM
Click SSL
I suggest you to go for multi domain certificate to encrypt your all three domains. You donít need various IP address to protect your multiple domain and sub-domains. You can secure multiple domains with single SAN Certificate. SAN Certificate can secure your both internal network names and external domain names.
SAN Certificate can cover all of the following:
- domain.com
- one.domain.com
- two.domain.com
- three.otherdomain.com
- xyzdomain.local
It will allow you to secure up to 25 domains even on a single server by installing UCC Certificate (SAN) from GeoTrust. It secures your main domain as well as up to 24 additional SAN domains.
< Message edited by Click SSL -- 16.Oct.2013 12:59:58 AM >
Secure Unlimited Sub-Domains with Wildcard SSL from ClickSSL.com - Trusted SSL Certificate Provider
