Website issues
All Forums >> [ISA Server 2004 Firewall] >> General >> Website issues Page: [1]
Website issues - 17.May2013 9:37:32 AM
excossack
We have a pair of ISA 2004 Enterprise server’s setup with NLB, each server has two NICs. (Both NLB’d and each NLB’d NIC is in a separate DMZ) External DMZ (192.*) Internal DMZ (10.*)
There is a publishing rule (1 of about 25) that publishes an internal webserver running IIS.
The publishing rule is set for http & https.
The publishing rule is set to listen on one IP address is defined and listens on the External DMZ
It listens for requests on www.<website>.com and for <website>.com
And directs traffic to the Internal DMZ
The webserver is on the same range of IP as the Internal DMZ.
The webserver runs IIS and hosts 4 other websites, also published via ISA.
Recently we have had issues with intermittent access to the websites from external sources.
What we have noticed, is.
www.<website>.com does not load and you get server busy message (not a standard IIS message but one from the application running on the webserver)
<website>.com will load and work OK.
If you use www and then specify a subpage that will also work
Today, it’s the reverse of the above and specifying a subpage after the domain works OK.
The other websites on the server load OK using either www or just <website2>.com
The websites work fine from inside the network as the traffic does not go via ISA
If we do a rule on the firewall to bypass the ISA server this works fine.
After the issues we had with NLB we thought the issue was resolved and it did work fine using www or <website>.com for about 3 days and now its playing up again.
A reboot of the ISA servers doesn’t resolve it neither does a reboot of the webserver.
Watching the traffic on ISA, I can see the request coming in and getting passed to the webserver and a GET is issued to the webserver and that’s where it stops and the error “sorry server too busy” is displayed.
I have tried firefox on Android, Firefox Portable, IE on a Windows 2003 server in the DMZ and the same happens.
Also the same at home as well.
I’m confused.
Any thoughts people?
John
Thanks.
John.
Wirral, UK
