Regain OST to PST Software to repair corrupt OST file and Convert OST File into PST File without any changes in your OST file. You can instantly convert an offline storage (OST) file to equivalent personal storage (PST) file. The software safely converts all mail items of Offline folder (OST) file and saves them in new Outlook PST file, along with giving option to save as EML, MSG, RTF, HTML file formats.It provides you best facility to split your large PST file into small PST file 1GB up to 5GB.It fastly to work on such all OST file version up to 2016.
The advanced OST to PST Conversion tool has really brilliant features with all the exclusive techniques. That’s why it is able to convert Microsoft Outlook PST files in exact style of formatting. Let’s have a look to its features:-
- Ensures surety of success with OST recovery/ repair
- Extracts all OST corruptions fabulously in minutes with few clicks
- Recover MS Outlook files from the badly corrupt OST database
- Quick and safe process of OST to PST conversion
- Uses effective techniques and methods to convert OST file to PST
- Helps to fix OST to PST from all versions including 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.
- Compatible with Windows 95, 98, 2000, XP, 2003, Vista, 7, 8 & Windows 10.
- Free Version Available, will see you the preview of recover original data, integrated with full features
Effortlessly convert OST mailbox data into PST file by using third party solution, such as, Exchange OST to PST. The software is also capable to perform conversion of Unicode characters. Apart from that, users can also convert OST mailbox data into EML, MSG, RTF, TXT, PDF, HTML, MHTML, MBOX and DBX file formats.
Try OST to PST Conversion Software and recover corrupted OST data and convert into Outlook PST format with all Emails, Contacts, calendar , Notes, entries, and journals.This software supports Windows 10, 8, 7, Vista, XP and MS Office 2016,2013, 2010, 2007, 2003, 2002 (XP). Read more information about this software and free download click here http://osttopstconversion-software.blogspot.com
It is very simple and easy but very time-consuming. I hope you have a lot of patience. if these techniques doesn’t work, then you may go for second methods.
2nd Method: Use Archive Feature.
1. Open MS Outlook application >> File menu >> Archive. 2. Select the file or folder for archiving. 3. Browse location to store the archived PST file >> click OK. 4. Archiving process will be start.
