This OST to PST Converter efficiently converts inaccessible or damaged OST files into readable PST files without causing any loss of data. It uses fast and efficient algorithms which allow the tool to convert calendars, emails, contacts, tasks, appointments, distribution lists, journals, meetings, and other important content. It allows user to save recovered mailbox data in MSG, PST, EML and DBX formats which can be accessed with Outlook Express and MS Outlook. It features easy to use interface which is self-descriptive, intuitive, and easy to understand. Even a new user can recover their OST files with this tool. Download our free trial version to check the accuracy of data conversion in preview before buying the full version.
Try OST to PST Recovery software and instantly repair corrupt OST files and convert Outlook PST format. This software also convert EML, MSG and HTML PDF format. Read more information and free download click here : http://osttooutlookpst.blogspot.com
Use the OST to PST Conversion Software and easily recover corrupted OST data and convert into Outlook PST format with all Emails, Send Items, Contacts, calendar , Notes, entries, and journals.This software supports Windows 10, 8, 7, Vista, XP and MS Office 2016,2013, 2010, 2007, 2003, 2002 (XP). Read more information about this software and free download click here http://osttopstconversion-software.blogspot.com
Hi, It seems you have an inaccessible OST file and you want to convert your OST file to PST format. I personally recommend you to use OST to PST Converter of any trusted brand as no manual solution will work if your OST file is orpahn or majorly corrupted. However, it's not so easy to implement manual technique for most conversions. Some third party solutions are providing their best services in the field of conversion. You can choose one of them according to your need, but firstly try the trial version of the tool.
