RE: Windows update doesnt work at Win. 2k3?
RE: Windows update doesnt work at Win. 2k3? - 13.Nov.2005 11:33:01 PM
Sunny.C
May i just addin that you should manually update your server's, especially if the server is a firewall. I have run into may problems before with microsoft updates effecting the O/S with auto live updates.
RE: Windows update doesnt work at Win. 2k3? - 14.Nov.2005 7:51:04 AM
iraq it
ORIGINAL: Sunny.C May i just addin that you should manually update your server's, especially if the server is a firewall. I have run into may problems before with microsoft updates effecting the O/S with auto live updates. Untill now i couldnt update the ISA firewall even with anonymous windows rule and do it manually. So you mean there is little risk with MS. updates? Thanks,
RE: Windows update doesnt work at Win. 2k3? - 14.Nov.2005 9:21:24 AM
sam_hunter
Are there no risks with applying patches? No. Are there no risks with not applying patches? No to that one as well. You have to look at your network. Is the vulnerability in your network such that you need to patch? What apps do you have that have historically had issues with patching? Will your LOB vendors support patching? Does your firm need a patch testing process? When's the best time to patch for your firm? I normally manually patch servers or at least ensure they are in their own patch schedule. I'd recommend you look at WSUS for a free patch tool for a network.
RE: Windows update doesnt work at Win. 2k3? - 14.Nov.2005 2:56:24 PM
I agree that you should not install patches on any server without testing them first. This is especially true on a firewall, that includes PIX and Check Point server, and ISA firewalls. Never install an untested patch. HTH, Tom
RE: Windows update doesnt work at Win. 2k3? - 14.Nov.2005 4:45:23 PM
iraq it
ORIGINAL: tshinder I agree that you should not install patches on any server without testing them first. This is especially true on a firewall, that includes PIX and Check Point server, and ISA firewalls. Never install an untested patch. HTH, Tom Well, i have anonymouse windows update rule to most producation servers but how can i test the update before install it, any idea ? Also, I couldnt untill now able to update the ISA firewall even i do it manually and i have the rule that allow local host, any idea? Thanks,
RE: Windows update doesnt work at Win. 2k3? - 15.Nov.2005 1:22:16 PM
Sunny.C
Do you mean you can update all servers but not the isa server??? The way i test patches before putting them on live is in a test lab with the exact same network layout.
RE: Windows update doesnt work at Win. 2k3? - 15.Nov.2005 2:19:22 PM
iraq it
ORIGINAL: Sunny.C Do you mean you can update all servers but not the isa server??? The way i test patches before putting them on live is in a test lab with the exact same network layout. Yes, except the ISA firewall. And how do you know its bad batches? Are Microsoft producing harm patches? Thanks,
RE: Windows update doesnt work at Win. 2k3? - 16.Nov.2005 1:38:26 PM
Sunny.C
Have your added the *.windowsupdate.microsoft.com into your rule???? Microsoft patches can sometimes effect O/S from working properly and do more harm then good, thats why we need to test before we use it live.
RE: Windows update doesnt work at Win. 2k3? - 18.Nov.2005 12:10:34 AM
Sunny.C
Just create a server's address range for the server's you want the rule to apply to or computer sets.(Exclude any server which you don't want the rule to apply to.)
RE: Windows update doesnt work at Win. 2k3? - 18.Nov.2005 2:58:44 PM
iraq it
ORIGINAL: Sunny.C Just create a server's address range for the server's you want the rule to apply to or computer sets.(Exclude any server which you don't want the rule to apply to.) So i will exclude some key servers and leave the test server so i cant test the update even i dont understand how can i know its harm patch! Thanks,
RE: Windows update doesnt work at Win. 2k3? - 20.Nov.2005 2:16:29 AM
Sunny.C
If that is the way you like to do it then yes.... The best way to test is have a identical server in a test lab.
RE: Windows update doesnt work at Win. 2k3? - 23.Nov.2005 11:00:44 AM
brian4answers
In internet connections on the Servers, try the following:- Tick Use a Proxy Server quoting IP Address of ISA Server, and Port 8080 Brian
RE: Windows update doesnt work at Win. 2k3? - 23.Nov.2005 4:39:18 PM
LLigetfa
While WinHTTP can glean proxy settings from your browser, I prefer to set it with the proxycfg CL utility.
RE: Windows update doesnt work at Win. 2k3? - 24.Nov.2005 7:50:55 AM
iraq it
ORIGINAL: brian4answers In internet connections on the Servers, try the following:- Tick Use a Proxy Server quoting IP Address of ISA Server, and Port 8080 Brian What will result by applying this? Thank,
RE: Windows update doesnt work at Win. 2k3? - 27.Nov.2005 10:02:26 AM
Sunny.C
If you tick that option your server will be using the proxy server for it's internet requests, I recommend using proxy for all your servers.
RE: Windows update doesnt work at Win. 2k3? - 27.Nov.2005 3:03:39 PM
iraq it
ORIGINAL: Sunny.C If you tick that option your server will be using the proxy server for it's internet requests, I recommend using proxy for all your servers. OK, thanks.
RE: Windows update doesnt work at Win. 2k3? - 27.Nov.2005 3:09:14 PM
LLigetfa
If you tick that option your server will be using the proxy server Setting proxy that way is a "per user" setting but Windows Update uses WinHTTP which runs under localsystem. As I already said, WinHTTP can *glean* the proxy settings from the user, but why leave it to chance? Use the PROXYCFG CL utility instead.
