Ok Dudes,This is a pretty intensive conversation!
Here's what I would do, and what I have done.
Get the DNS off the ISA Server, its not good security policy and you should really remove all services not required on the ISA Server.
Install an internal DNS Server. That DNS Server should be authoritative for your internal domain. It should also be configured to forward requests to an external DNS Server for domains for which it is not authoritative.
Make sure that there is a protocol rule in place that will allow the internal DNS Server to forward requests to an external DNS server, and make sure that the internal DNS server is configured as a SecureNAT client.
The Exchange Server should be set up as a SecureNAT client. Because SecureNAT clients cannot use the ISA Server to perform a proxy DNS for them, you have to configure their DNS setting manually. Set the Exchange Server to use the internal DNS server to resolve host names.
Run the Secure Mail Wizard, and you're set for life!
