RE: DMZ Configuration
All Forums >> [ISA Server 2000 General] >> General >> RE: DMZ Configuration Page: <<   < prev  1 [2]
RE: DMZ Configuration - 4.Apr.2001 1:57:00 AM
jmunyan
No. Same subnet different adapters. Would be like dual homing into one vlan. I think the best situation given the lack of ips is no dmz. Personally, I think the non dmz configuration is the best anyways. None of that routing only resource access garbage.
I hope they manage to instantiate multiple instances of the nat translator in the next version.
John
(in reply to TheJackal)
Post #: 21
RE: DMZ Configuration - 4.Apr.2001 3:44:00 AM
WalkerB
Fair enough. Was a random thought that drifted into my head as I finished the more standard not enough IP answer
Not sure that I agree with your sentiments on DMZs - I think that the concept of a layered defence is a sound one.
Walker
Post #: 22
RE: DMZ Configuration - 4.Apr.2001 4:42:00 AM
TheJackal
Well, my situation that I MUST use "NO DMZ" because we have T1 with Cisco Router preconfigured with only one subnet 255.255.255.0/254 routable IP addresses. And we are not allowed to get into Cisco Router to divide the current subnet into smaller subnets. Then I MUST HAVE BEEN GONE WITH "NO DMZ" AT ALL.
- The only thing I can do DMZ that I should ask my ISP to reconfigure subnet in the router to be smaller subnet ....well thats not allowed ..:-((.
- After all, for getting use of DMZ feature of ISA , we have to have bunch of IP addresses in different at least 2 subnets. And this is not applicable for my case with one subnet preconfigured in Cisco Router already. Good luck guys.
PTH
Post #: 23
RE: DMZ Configuration - 5.Apr.2001 5:23:00 PM
jst3751
I have just read through all of the discussion. However, I am still not quite sure how to set up the DMZ. We are assinged a public address range of say 10.10.10.0/24 with a mask of 255.255.255.0. This is how I currantly have the 3 nics configured;
External to T-1: 10.10.10.4
255.255.255.0
10.10.10.1
DMZ Zone 10.10.10.5
255.255.255.0
Internal LAN 192.168.10.5
255.255.255.0
We have our own pubic available DNS servers along with websites, all are in the DMZ zone. If what my understanding of what I have read is correct, then I would need to ?change the subnet mask on the DMZ to 255.255.255.128? If so, what would be the available address to use on the DMZ? 10.10.10.129-254? or 10.10.10.0-128? The DNS servers are registered in Bulk register as say 10.10.10.11, 10.10.10.12 and 10.10.10.13. The websites are registered in zones on the DNS servers as 10.10.10.101-245. So if I have to subnet, then it seems as if the above addressing sceme I am currantly using will not work.
I do not yet have ISA installed, I am prepairing the network configuratin and all the addresses and the routing table and NAT on the 2000 server that I will be installing the ISA server on Saturday.
Any help is welcome.
Post #: 24
RE: DMZ Configuration - 5.Apr.2001 6:14:00 PM
jmunyan
The DMZ subnet has to be made up of public ip addresses.
Since access between dmz and front interface is done by traditional routing, the subnet on the dmz must be routable through the front facing interface.
So you have to divide your isp given subnet up into two subnets one for the dmz and one for the front facing interface.
John
Post #: 25
RE: DMZ Configuration - 5.Apr.2001 6:33:00 PM
jst3751
John
OK, I can do that. By how, changing the mask to 255.255.255.128 or 255.255.128.0? And then the address block to use in the DMZ would be what, 10.10.10.0-127? Or rather 10.10.10.128-256 so I don't have to reconfigure the T-1 router? Then would all nodes (servers and websites) on the DMZ have to be in that address block range? That means I'll have to reasign address.
Post #: 26
RE: DMZ Configuration - 6.Apr.2001 6:06:00 PM
jst3751
Would someone please be kind to respond to my above post?
Post #: 27
RE: DMZ Configuration - 7.Apr.2001 10:44:00 AM
Hi Jst,
For the DMZ,
The first IP address would be:
W.X.Y.(1)0000001
The last IP address would be:
W.X.Y.(1)1111110
Tom Shinder
Post #: 28
RE: DMZ Configuration - 8.Jun.2001 5:29:00 PM
Ultraman
jcentimano,
I hate to dig this back up, but I have a similar problem as you've described, but I have eight IP's to work with instead of five.
Is the configuration you mentioned above viable for eight IP's and, if yes, could you lay it out in a "practical example?"
xxx.xxx.xxx.248 (network)
usable range .249-.254
DSL Router
IP xxx.xxx.xxx.249
Mask 255.255.255.252
NIC-1(external)
IP xxx.xxx.xxx.250
NIC-2(DMZ)
IP xxx.xxx.xxx.253
NIC-3(internal)
192.168.254.1
255.255.255.0
I know I'm close - but this bugger just doesn't work. If you could straighten me out and give some BASIC packet filters in and out to get it fired up I'd appreciate it.
Thanks muchly!
Eric Jansen
HMG Technologies, Inc.
Ellicott City, MD
MCP, ICE, ICA
Post #: 29
