Originally posted by isafan:
DBH,Out of curiosity, why do you not want to use the web cache on ISA? It's good, and fast. In general I'd say that it's best to have it on (using the web proxy settings in the browser).
I did experiment on a 2K Pro machine to make sure it works and it does.
I wonder if port 80 TCP is being blocked somehow. It should not be though with your protocol filter.
The really odd thing is that you said it worked when you set up the proxy settings in the browser, but FTP would not work.
Just for kicks, try disabling that protocol filter and making a new one. Set that up for "selected protocols" and select all the HTTP and FTP protocols listed, apply it, and make sure it's running. Stop and start the ISA services (cache, firewall, and download I believe), then try connecting again. First from ISA itself, then from the client.
I'm curious to see what happens after that.
isafan.
