blocking access to a destination set disrupts other rules
All Forums >> [ISA Server 2000 General] >> General >> blocking access to a destination set disrupts other rules Page: [1]
blocking access to a destination set disrupts other rules - 23.Apr.2002 3:44:00 PM
abeeber
Hi everyone,
I have a weird problem. I have a fairly liberal access rules policy (allow all outbound access). However, I wanted to deny access to a streaming media site (media.mediaxtranet.net). So I created a destination set to that site (in my testing I tried both domain name ie *.mediaxtranet.net and IP address and IP address range). When I enable it the rule works. Users who are streaming from that site get disconnected.
HOWEVER, and here is my problem. My DBA has a job that connects to a sql server to pull data from this data service. When my deny rule to mediaxtranet.net is enabled. This job fails. The sql server is on a different domain and IP address.
Also I have tried deny only audio traffic to the mediaxtranet.net site and still sql connect gets blocked.
Andrew
RE: blocking access to a destination set disrupts other... - 24.Apr.2002 12:22:00 AM
Hi Andrew,
That's quite odd. I don't see how a site not at all related to the one that is blocked would have an effect on the other. What do the log files say about these connections?
(in reply to abeeber)
RE: blocking access to a destination set disrupts other... - 24.Apr.2002 3:35:00 PM
abeeber
This is the frustrating part. When I check the firewall log, it shows a sucessful connection via TCP 1433.
However, then my deny rule is enabled. I see on the packet filter log Blocked UDP packets from the SQL Server we are trying to pull data from.
I check microsoft's knowledge base and they meantion the use of UDP 1024-5000 as part of a 3-way handshake between a sql client and a server.
What frustrates me is that the connect works when my deny rule is disabled.
I have also tried creating a protocol definition for this UDP range and still no luck.
Andrew
