RE: Discussion on Kaaza article
RE: Discussion on Kaaza article - 29.Jan.2004 4:05:00 PM
Scorpio
The article solution worked OK for me, but I have another challenge: DC++ or oDC do not work with these settings (in this case is port 411 outbound, plus secondary connection inbound). Tried everything I could think about, and I only managed to connect to the hubs, but not to other users. It's only working when I turn off packet filtering. Please help.
RE: Discussion on Kaaza article - 6.Jun.2004 1:41:00 PM
Robert Ferrazzola
I too have followed the manual but still can not ket kazza to work i have the firewall clien installed and still no luck.
please help
RE: Discussion on Kaaza article - 23.Jun.2004 11:59:00 PM
Adamzman
I love it, it works perfectly. Now all I need is a way to allow Bit torrent to work through ISA and I'm sorted
RE: Discussion on Kaaza article - 25.Aug.2005 10:06:00 PM
JarrodV
G'day, i have a ISA 2004 server and i am trying to forward TCP connections. I am using Emule a p2p file shearing program. and this is what i get on my client computer
Testing IP: CPE-144-132-113-89.vic.bigpond.net.au (144.132.113.89)
Starting TCP connection test... TCP test failed! UDP test will not be performed.
Connection test finished.
Results in detail:
TCP connection test failed. It was not possible, to establish a TCP connection to your eMule. Other users will only be able to connect to you with the help of a server, resulting in a low ID for you. While eMule still works, this will give you several disadvantages. Therfore it is highly recommended to solve this problem.
I have folowed simular steps that you guys took with Kazaa and just changed the port numbers. but still no luck!
-------------------- Jarrod
RE: Discussion on Kaaza article - 11.Sep.2005 1:28:00 PM
Quicksurf
Dear guys ,
I had tha same problem using kazaa on isa server 2000 sp2
I downloaden an socks 5 add in for isa server 2000 that goes by the name surrogate socks 5.
disabled the default socks 4 .created the theprotocol rules tcp inbound 1214-8000
in the kazza options remove the option that disables the "do not use port 1214" option
where you configure your firewall setting fill in every field authautentication ... and change the default port to 2724
