RE: Discussion of Publishing OWA 2003 article
RE: Discussion of Publishing OWA 2003 article - 20.Jul.2003 12:08:00 AM
brokenribgolfer
Tom,
Thanks for the set of articles. Makes sense and works great! One question though: Is there any way to require the external OWA client have the certificate imported before even gaining access to the OWA site? It appears that this procedure protects the transmission of unencrypted data from the client through to the Exchange server (and back),,,, but it does not keep anyone from connecting and attempting to guess a valid username/password. I would prefer that an external client without a valid certificate installed simply receive an access error.
Am I wrong about this? (Always the most likely possibility)
Thanks again.
Mark
RE: Discussion of Publishing OWA 2003 article - 21.Jul.2003 2:19:00 AM
SanMan
Hi there,
When I redirect root to default.asp to <% Response.Redirect "/exchweb/bin/auth" %>
I am able to login thereafter I get the following error when accessing owaauth.dll
Blank page with
Unspecified error
Any Ideas
SanMan
ps. normal redirect to /exchange works fine and without redirection problem persists.
RE: Discussion of Publishing OWA 2003 article - 21.Jul.2003 5:54:00 AM
Nobbyness
quote: Originally posted by tshinder: Hi Rob,
I wasted a day this week trying to figure it out. I suspect the problem is that you need to hard code the RPC ports. I did get it to work with a Web Publishing rule with a /rpc* for the path along with the /exchange*, /public* and /exchweb* paths. The problem was that it was extraordinarily slow. It may have been a problem with my scenario, because I co-located the Exchange Server with a DC, and the docs say that you need to use a FE/BE config for it to work. I'll try that next week and report my finding for Exchange RPC over HTTP when I get a definitive finding.
Thanks! Tom
Could you point me at the docs you're referring to? I've hunted all over (mainly the MS site), but all I've come up with relates to configuring the client side. Zilch on either Exchange 2003 or ISA on the subject of RPC over HTTP.
Thanks. Pat.
RE: Discussion of Publishing OWA 2003 article - 23.Jul.2003 4:01:00 PM
Thanks again.
Mark
Hi Mark,
You can certainly use client certificate authentication at the ISA firewall and basic auth at the Exchange site! That might be a good article for the future. Check out my client certifiate authentication article over at www.isaserver.org/shinder
HTH, Tom
RE: Discussion of Publishing OWA 2003 article - 5.Aug.2003 10:38:00 AM
SanMan
Hi Belinda, Have u checked your DNS internal(have u created a zone file or host) and external(ISP).
HTH
Hi Tom, How is the motivation coming along for an RPC document ?
Thank you, SanMan
RE: Discussion of Publishing OWA 2003 article - 5.Aug.2003 11:13:00 AM
belindam
SanMan,
I have not created any DNS entries for the server. I previously had all OWA and external exchange server access working without an issue. Troubles arose when i enabled Packet Filtering. Since then i cannot access externally.
What DNS entries do i need to create?
Belinda
RE: Discussion of Publishing OWA 2003 article - 5.Aug.2003 12:15:00 PM
belindam
SanMan,
Belinda
RE: Discussion of Publishing OWA 2003 article - 5.Aug.2003 11:31:00 PM
SanMan
Belinda, Does interal work when you goto http://mail.domainname.com.au/exchange ? Use nslookup to check.
Does domainname.com.au = FQDN ? If not create a zone for this.
Does external work when you goto you external url ?
Packet filtering should not affect this as it is published.
Hope that helps you out a lil. SanMan
RE: Discussion of Publishing OWA 2003 article - 6.Aug.2003 7:02:00 AM
quote: Originally posted by SanMan: Hi Belinda, Have u checked your DNS internal(have u created a zone file or host) and external(ISP).
HTH
Thank you, SanMan
Hi SanMan,
The word is that the motivation might increase significantly this week. I'll let you know what happens. If the deal goes thumbs up, you can look forward to this info next week.
HTH, Tom
RE: Discussion of Publishing OWA 2003 article - 6.Aug.2003 7:04:00 AM
Belinda
Hi Belinda,
You must have packet filtering enabled. Packet filtering is the first line of defense, and if it is disabled, the server is wide open to every exploit known to man. In fact, if packet filter has been disabled, and this machine was connected to the Internet, I would reformat and reinstall as there is a good chance the machine has already been compromised.
HTH, Tom
RE: Discussion of Publishing OWA 2003 article - 6.Aug.2003 7:05:00 AM
quote: Originally posted by SanMan: Belinda, Does interal work when you goto http://mail.domainname.com.au/exchange ? Use nslookup to check.
Hi SanMan,
I think part of the problem is that a split DNS is required, which is a real problem if you only have a single server, since you need at least two servers to create the split DNS *if* you are hosting your external records yourself.
HTH, Tom
RE: Discussion of Publishing OWA 2003 article - 16.Aug.2003 2:39:00 AM
BDreeszen
Tom, Great Article! I have set this up on one of my clients servers and it works like a million bucks! Here is my dilema...... The server with OWA is also running a Web server for the company (Real Estate). So mydomain.com goes to the web server and mail.mydomain.com goes to the web server also. In the past they have just had to put /exchange at the end of the URL. Now they have to put https: and /exchange etc. etc. in the url. This is generating a lot of call volume at my help desk. I'd like to keep this security measure in place as there is a lot of confidential information being swapped around. Have you got any ideas as to how I can set it up so that when the url http://mail.mydomain.com is entered, its redirected to https://mydomain.com/exchange. I read in one of your earlier posts that you thought someone was playing games or being lazy, I would have to agree, but this is getting past lazy and its starting to take a dent in my pocketbook. Any thoughts would be appreciative! Thanks Brian
RE: Discussion of Publishing OWA 2003 article - 20.Aug.2003 7:32:00 PM
Hi Brian,
You can create a page with a meta tag so that when users go to http://mail.domain.com it automatically redirects them https://mail.domain.com/exchange
If you're going to run a second Web site on the Exchange Server, I'd recommend creating a second virtual Web server for the site.
HTH, Tom
RE: Discussion of Publishing OWA 2003 article - 25.Aug.2003 1:16:00 PM
TaN
Hello! I've read your article ans I think that it is very good! I haven't started materialize it yet but I'm going to! Well, I have an Exchange 5.5 server running in a Win2000 Server and an ISA server running in Win2000 Server, too. Both of them are members of a 2003 Domain. I want to publish my Exchange server on the Internet using Exchange OWA and SSL in order to my clients have access at their mails via internet. I don't have an OWA site, just an Exchange Server. Can these articles work in my case? [ August 25, 2003, 02:56 PM: Message edited by: TaN ]
