RE: Two Internet connection - Route add?
RE: Two Internet connection - Route add? - 8.Dec.2003 7:44:00 PM
_satu_
Hi Stefaan,
here are the detailed configuration settings. I changed the configuration, to heal our website, and I marked with **** where the configuration was changed.
Connections: 0x1 ....... MS TCP Loopback interface 0x2 ....... 3Com EtherLink PCI 0x1000003 . WAN (PPP/SLIP) Interface 0x1000004 . Intel(R) PRO Adapter 0x1000005 . Broadcom NetXtreme Gigabit ========================== Persistent routes: Dest Mask Gateway Connection 0.0.0.0 0.0.0.0 195.199.54.190 195.199.54.189 10.111.110.0 255.255.255.0 10.111.110.30 10.111.110.30 10.111.110.30 255.255.255.255 127.0.0.1 127.0.0.1 1 10.111.110.221 255.255.255.255 127.0.0.1 127.0.0.1 1 10.111.111.0 255.255.255.0 10.111.110.29 10.111.110.30 1 10.111.112.0 255.255.255.0 10.111.110.28 10.111.110.30 1 10.255.255.255 255.255.255.255 10.111.110.30 10.111.110.30 1 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 192.168.1.0 255.255.255.0 192.168.1.2 192.168.1.2 1 192.168.1.2 255.255.255.255 127.0.0.1 127.0.0.1 1 192.168.1.255 255.255.255.255 192.168.1.2 192.168.1.2 1 195.199.0.0 255.255.0.0 195.199.54.190 195.199.54.189 1 195.199.54.176 255.255.255.240 195.199.54.189 195.199.54.189 1 195.199.54.188 255.255.255.255 127.0.0.1 127.0.0.1 1 195.199.54.189 255.255.255.255 127.0.0.1 127.0.0.1 1 195.199.54.255 255.255.255.255 195.199.54.189 195.199.54.189 1 224.0.0.0 224.0.0.0 10.111.110.30 10.111.110.30 1 224.0.0.0 224.0.0.0 192.168.1.2 192.168.1.2 1 224.0.0.0 224.0.0.0 195.199.54.189 195.199.54.189 1 255.255.255.255 255.255.255.255 192.168.1.2 192.168.1.2 1 Default gateway: 195.199.54.190 ***** WAS: 192.168.1.1 =========================================================================== Persistent routes:
10.111.111.0 255.255.255.0 10.111.110.29 1 10.111.112.0 255.255.255.0 10.111.110.28 1
****195.199.0.0 255.255.0.0 195.199.54.190
IP . . . . . . . . . . . : argosz DNS . . . . . . : .....net.hu Hibrid IP routing. . . : Yes WINS-proxy . . . . . : Nem DNS search. . . : .....net.hu
Ethernet-adapter - BDSL DNS suffix. : DHCP . . . . . . . . : No IP. . . . . : 192.168.1.2 Subnet. . . . : 255.255.255.0 Default GW. . . . . . : ****was: 192.168.1.1 DNS . . . . . . . . . : 192.168.1.1
Ethernet-adapter - Kozos 3Com 3C996B Gigabit Server NIC IP. . . . . . . : 10.111.110.30 Mask. . . . . : 255.255.255.0 Default GW. . . . . . : DNS . . . . . . . :10.111.110.20 10.111.112.20
WINS. . . . : 10.111.110.20 WINS. . . . : 10.111.112.20
Ethernet-adapter - Kulso. . : Intel(R) PRO/100 VE Network Connection IP. . .. : 195.199.54.188 MASK. . . : 255.255.255.240 IP. . .. . . : 195.199.54.189 (second one!) MASK. . . . . : 255.255.255.240 Default GW. . . . . . : 195.199.54.190*** was - DNS . . . . . . . . . : 195.199.0.125 195.199.0.121 NetBIOS . . . . . . : Disabled
If you feel a little bit unsure, please read my previous article posted December 05, 2003 05:34 PM. I think it is not so difficult.
Thanks, Gabor
RE: Two Internet connection - Route add? - 8.Dec.2003 8:44:00 PM
_satu_
Ok, I red the articles, and that was clear before.
When ISA was originally set up for the two connection, it has only ONE default gateway, on the 192.168... NIC. On the perimeter NIC (195.199.55....) wasn't any default GW-entry.
I think the routing was correct, because everyone could surf on the net, no matter whether they get a page from the 195.199 subnet, or from anywhere.
I think, there weren't any problems, if the default GW would be the 195.199.54.190. Because in this config, every session from outside came in on that interface. (Because our DNS-name is that!) And nobody wanted to get in on the other interface, because it hadn't a DNS name!
But I can't do that! I can isolate only the 195.199 segment.
Thx, Gabor
RE: Two Internet connection - Route add? - 9.Dec.2003 11:16:00 PM
_satu_
Yes! Ok, then we talk about the same.
So, to sum up everything... The ISA doesn't support the two Internet connections except you have a DMZ, which is on a particular subnet (no matter whether it has private or public IP.) and you can reach these machines only on the DMZ interface, and they can see only the DMZ interface.
Stefaan, thanks a lot, you helped very-very much.
Gabor
RE: Two Internet connection - Route add? - 10.Dec.2003 9:13:00 PM
Hi Gabor,
well, in fact the configuration can be a little bit more complex! Let's draw a little schema: code:
LAN --- [ISA] --- [RTR1] --- Internet ! ! NetID2 ! +--- [RTR2] --- WAN --- [RTR3] --- [Servers] NetID3
The ISA default gateway is set on the ISA external interface and points to the LAN interface of RTR1. Also, no default gateway is set on the ISA DMZ interface. On ISA you define a persistent static route for the NetID3 reachable through the DMZ interface with as gateway the LAN interface of RTR2. So, ISA knows 2 routes through his DMZ interface: NetID2 (directly connected) and NetID3.
Now, if an internal host wants to access a destination on NetID3, then the normal outbound policy will be applied (protocol and site&content rules) and ISA will route that traffic to RTR2. The source IP address will be the primary IP address assigned to the ISA DMZ interface.
It should be clear now that the servers on NetID3 should route the responses back through RTR3. In other words, seen from NetID3, NetID2 should only be reachable through RTR3. This is very important. The above means also that any service you publish on the ISA DMZ interface will be reachable from NetID3.
HTH, Stefaan
RE: Two Internet connection - Route add? - 18.Dec.2003 7:36:00 PM
cabaldochoa
I have two ISAs in array (this is only for cache), each one with a internet connection so, to allow internet acccess to internal pcs through ISA, the DNS server is set up with round-robin.
RE: Two Internet connection - Route add? - 6.Jun.2004 4:20:00 PM
But there is nothing more cheaper?
quote: Originally posted by tshinder: Hi Gabor,
Check out www.rainfinity.com and RainConnect. That's the only way other than BGP.
HTH, Tom
