bitconfused
Hey Tom, Thanks for the reply; I would like to know the impact of switching from my current config to Edge. If I have typical (mail, DNS, RDP and Web rules) is it a big issue to switch with ISA 2004? As for learning more on templates, I will switch back one way or another, and to understand them better I have gone and purchased another one of your books, "Dr. Tom Shinder's Configuring ISA Server 2004". If there is a better option please let me know. ;-) As for my issue, I am able to send mail from the mail server to the outside world without issue, through the DMZ (not ISA but the physical one created by having the two firewalls). However, when in the DMZ I can not telnet to port 25 on the published IP of the ISA Server. Meanwhile, while in the DMZ I can telnet to other published services on their native ports IMAP, PPTP, POP3, HTTP...all work fine when I publish them. Here is the strange part, I can telnet to my exchange server, from the DMZ, "IF" I tell ISA to listen to port 3232 (randomly assigned) via telnet. Then I forward inbound port 25 from the Cisco's internet side and translate it to 3232 so the it hits the 3232 being listened for on the SMTP published IP (my workaround), weird, I know! I know my forwarding rules on the Cisco are correct as I can access all of the aforementioned services through the Cisco into my DMZ and subsequently through ISA into my backend network. I have also gone as far as to use other routers that are forwarding SMTP in other locations backing up their config, and uploading it to a spare, making the appropriate changes for my network only to end up with the same results. :-( Also I must apologize as I did not understand your last question? "Since you're NATing from the Internet through the Cisco to the ISA firewall's external interface, what Network Rule applies to the connection from the IP address on the Cisco LAN interface and the ISA firewall Network to which the SMTP server belongs?" I believe the rules on the Cisco are correct as other routers (Linksys BEFSX41 and RV08) and yield the same results. On the ISA external interface I have my services published as to allow the ISA to listen for them based on the port and they all work, except port 25 on the SMTP server rule. I am not sure if I have correctly answer your question, if not could your possibly re-phrase? Thanks for you guidance! :D Bit.
