RE: Discussion about article on publishing PASV FTP Serverw
RE: Discussion about article on publishing PASV FTP Ser... - 23.Apr.2005 6:16:00 PM
rasool
dear friend please advice me how to publish FTP server with ISA 2000 server
RE: Discussion about article on publishing PASV FTP Ser... - 27.Aug.2006 4:33:39 AM
ezpcc
Ok.. so I have read all of this information but still have issues.. and it does not seem that this topic went any further... Using Serv-U and ISA 2004 trying to make a regular FTP connection works fine but using SSL does not. Did this topic continue elsewhere??? THanks
RE: Discussion about article on publishing PASV FTP Ser... - 27.Aug.2006 11:30:14 AM
Hi ezpcc, as far as I remember, that article wasn't very accurate and was therefore taken offline by the author. Because it was a very interesting topic, we discussed it further offline with the author. This offline discussion resulted in a new and very good article Publishing Secure FTP Servers behind ISA Firewalls by the same author. So, check it out! HTH, Stefaan
RE: Discussion about article on publishing PASV FTP Ser... - 27.Aug.2006 5:10:42 PM
ezpcc
Thanks spouseele for the quick response.. that is the article I was trying to follow.. but I am still having a couple issue. Alhough using an ftp client it works out of the box per the article, I can not get the SSL piece to work. Also, I did not use the port numbers as described in this article.. should I have.? thanks
RE: Discussion about article on publishing PASV FTP Ser... - 27.Aug.2006 9:11:28 PM
Hi ezpcc, in part two and three the port numbers are crucial to get it working. What is configured in the FTP server should exactly match what is configured in the custom FTP protocol definition. HTH, Stefaan
RE: Discussion about article on publishing PASV FTP Ser... - 28.Aug.2006 4:21:40 AM
ezpcc
Hi Spouseele, One thing with my setup, I have a dynamic IP and am using a router in front of the ISA server. I have opened all ports from the router to the external nic on the ISA server for all services that I need to pass. I have also successfully implemented parts 1 and 2 of this article. The one thing I forgot to do uas setup the PASV mode with my external IP address. Once I did that part 2 worked. Unfortunatly, I have still not been able to get part 3 working...seems that I am once again missing something.. am going to call it a night and try again in the morning freash.. any ideas on what I could be missing here...?? Thanks
RE: Discussion about article on publishing PASV FTP Ser... - 28.Aug.2006 8:24:34 PM
Hi ezpcc, if scenario 2 works without the FTP Application Filter then scenario 3 should also work. As far as the ISA server is concerned, it is the same setup. HTH, Stefaan
