RE: Discussion for article on Supporting Forms-based auth and Basic Auth with one IP
All Forums >> [ISA Server 2004 General ] >> Exchange Publishing >> RE: Discussion for article on Supporting Forms-based auth and Basic Auth with one IP Page: <<   < prev  1 2 3 4 [5]
RE: Discussion for article on Supporting Forms-based a... - 28.Sep.2007 7:12:29 AM
I don't thnk that OWA supports that port transition, so you'll have to use another method or use ISA 2006.
(in reply to bonzo)
Post #: 81
RE: Discussion for article on Supporting Forms-based a... - 6.Nov.2007 12:53:31 PM
iwatkins
Still using ISA2004 here :-)
We do not have the Certificate Service installed on any internal machines (it is unnecessary and complicates things!) so is there anyway to get a certificate created that we can use in this method?
If not, I think we may have to splash on another external certificate and use a second external IP address.
Thanks.
Ian Watkins
Post #: 82
RE: Discussion for article on Supporting Forms-based a... - 11.Nov.2007 11:53:53 AM
If you have a second external IP address to use, then that is definitely the best way to go.
(in reply to iwatkins)
Post #: 83
RE: Discussion for article on Supporting Forms-based a... - 22.Apr.2008 12:01:29 PM
plysaker
All,
I hope that taking the time to post on a 2 year old stale fourm post is worthwhile.  If it saves some shmuck the 8 hours of hell I just went thru, great.'
Tom's tutorial is incorrect!  The cert request procedure for local host DOES NOT produce a PFX type cert.  .CER, .P7B etc are produced, but the cert i snot visible / seen by ISA when attaching to the listener.  You see it in the store allright, but you surely do not in the listener properties config.
I was fianly able to create the localhost cert via another computers IIS, and generating a cert req.  The IIS was independant, and was stand alone.  The key element is to get a PFX cert, with exportable key.
LOCALHOST Certificate listener computer store PFX not P7B not CER ISA FBA
Post #: 84
RE: Discussion for article on Supporting Forms-based a... - 22.May2008 7:30:49 PM
pete_h
plysaker:
Thanks for posting this - I've been pulling my hair out too. All was working for ages, but after a disk failure on the firewall, I restored from backup, and everything worked fine except the mobile phones now no longer authenticated properly, even though they did before. So ActiveSync was, and still is, screwed. Turns out the "localhost" certificate has become "detached" from the listener. However, when trying to reattach it, it doesn't show up in the list of certificates, despite it appearing fine in the local machine's certificate store, via the MMC's certificate console.
I'll try your suggestion, and post back my experience.
The ISA2004 firewall's been doing a fine job for what we need it for, so don't see the point of moving to ISA2006 for the sake of it, so would prefer to fix this one problem.
(in reply to plysaker)
Post #: 85
RE: Discussion for article on Supporting Forms-based a... - 27.May2008 8:45:47 AM
Hi Pete,
Make sure that the certificate you're binding to the Local Host Web Listener has a private key. That's the most common reason for it not showing up in the list in the ISA Firewall console.
(in reply to pete_h)
Post #: 86
RE: Discussion for article on Supporting Forms-based a... - 28.May2008 1:30:55 AM
pete_h
Thanks for the reply Tom :)
Seems odd that it would recognize it before, but not now after a backup restoration. Anyways, seems like the  way to go is to create another LocalHost certificate, but I'm not sure about this:
Both the external and localhost listener certificates were originally created using a CA installed on my SBS2003 server. The CA services have since been de-installed, and when I go now to reinstall them, the installation wizard tells me that the server "mailserver" (my SBS server's name and the name I used when first installing the CA service to create the initial certificates) has an existing private key, and "do I want to overwrite it with a new one?". If I say yes to this, does it make the existing external certificate invalid and unuseable? If so, this would cause me to have to update all the phones that use ActiveSync (that's broken now anyway), and the external web clients with new certificates, so that's not the prefered path.
ISA2004 is on a separate Win2000sp4 Advanced Server box (joined to the domain), and Exhange is on a SBS2003sp2 box.
So how do you suggest I proceed to create a new localhost certificate?
Post #: 87
RE: Discussion for article on Supporting Forms-based a... - 28.May2008 1:37:12 AM
pete_h
BTW, I do have a copy of ISA2006 sitting here, so there is the option of upgrading if you advise it strongly enough. Is the process of an inplace upgrade a smooth one? i.e. will it keep all my existing rules, or will I have to set it all up again?
Post #: 88
RE: Discussion for article on Supporting Forms-based a... - 28.May2008 9:21:15 AM
I would recommend just upgrading to ISA 2006, then you don't even need to deal with the "local host" Web Listener.
Post #: 89
Page:   <<   < prev  1 2 3 4 [5] << Older Topic    Newer Topic >>
