RE: Discussion of OWA FBA Publishing article
RE: Discussion of OWA FBA Publishing article - 1.Oct.2004 7:58:00 AM
Hey guys,
You can check out my OWA publishing articles and see if they help.
HTH, Tom
RE: Discussion of OWA FBA Publishing article - 1.Oct.2004 10:08:00 AM
clynn,
What have you entered in the server to publish field? is it an IP or FQDN? Are you bridging to 80 or 443? Is ISA a member of the domain?
RE: Discussion of OWA FBA Publishing article - 1.Oct.2004 11:52:00 PM
clynn
ISA is a member of the domain. Did so so I could RWW to it from home.
I published the server with the same name as the certificate: SERVERNAME.DOMAINNAME.com
FYI... SBS2003 is my Exchange server, SERVERNAME.DOMAINNAME.local
Published name is SERVERNAME.DOMAINNAME.com
LMHOST on ISA has SERVERNAME.DOMAINNAME.com pointing to the IP of SERVERNAME.DOMAINNAME.local
Got a link to that article, Tom? [ October 01, 2004, 11:56 PM: Message edited by: clynn ]
RE: Discussion of OWA FBA Publishing article - 3.Oct.2004 9:58:00 PM
quote: Originally posted by clynn: ISA is a member of the domain. Did so so I could RWW to it from home.
Hi C,
But the ISA firewall isn't on the Exchange/DC, right?
Thanks! Tom
RE: Discussion of OWA FBA Publishing article - 4.Oct.2004 4:34:00 PM
clynn
quote: But the ISA firewall isn't on the Exchange/DC, right?
That is correct. ISA is dual-homed on a stand-alone Windows 2003 Std Server. It has a static IP.
I am able to access OWA from the ISA Server, but I get a pop-up for authentication instead of the form-base page.
RE: Discussion of OWA FBA Publishing article - 5.Oct.2004 12:50:00 PM
Hi C,
OK, did you set the Web listener to use FBA instead of basic auth?
Thanks! Tom
RE: Discussion of OWA FBA Publishing article - 5.Oct.2004 2:44:00 PM
dclapp
I know they have HUGE concerns over joining it to the domain -because if ISA 2004 was compromised then the Windows networking security could be attacked directly (but, believe me I am on your side, I have never seen this). So the whole idea of a bastion host should work. I talked to Microsoft about this and they said it is perfectly fine not to have the ISA 2004 joined to the domain -I will test this scenario.
The ISA 2004 is a stand alone Windows 2003 Standard Server. It is not Exchange 2003 and it is not a Domain Controller (it's a member server in a work group).
The always authenticate is interesting. I was thinking of shutting this off (it is on). But, I seem to remember things really failing then.
All this confuses me. ISA 2004 with FBA turned on publishing OWA does not authorize credentials -it simply forwards the credentials to the OWA Front End Exchange server. However, if always athenticate IS ON then I might be confusing ISA 2004.
Hmmm... Any thoughts?
RE: Discussion of OWA FBA Publishing article - 5.Oct.2004 8:29:00 PM
jsarabia
Hello. I have OWA running using FBA through ISA over the Internet. I'd like to setup FBA for external and internal users. I know I can't enable FBA on the Exchange Virtual Server since that will break the FBA through ISA. I've tried modifying the Listener to listen on the Internal network, but I am unsure how the name resolution will work since the hostname on the certificate resolves to one IP address (the Exchange Virtual Server) and the hostname for the internal users resolves to another (the ip address of the listener on the internal interface). What should I do to make this work?
RE: Discussion of OWA FBA Publishing article - 6.Oct.2004 5:06:00 AM
dclapp
Today, I set up a test lab and implemented the "ISA Server 2004/Exchange Server Deployment Kit: Publishing Outlook Web Access using a Unihomed (Single-NIC) ISA Server 2004 Web Proxy" from the "ISA Server 2004/Exchange Server Deployment Kit".
This document is great and very detailed.
I was able to achieve publishing OWA on a Front End Exchange 2003 server using a unihomed ISA 2004 Web Proxy server. The ISA 2004 server was not a part of a domain. And it did a very good job of forwarding the credentials entered on the fake FBA page to the FE Exchange 2003 OWA (IIS).
Now, why would this work when ISA 2004 is installed in web proxy mode, but not when I have it in firewall/proxy mode (dual NICS).
I will definitely need to do more testing. I know I did not have ISA 2004 Require Authentication option checked. The document I read stated that ISA 2004 should not participate in authentication of an FBA login -instead it just forwards the credentials entered to the OWA IIS server.
The most interesting thing I learned about is SSL during this whole excericie/lab. Important: If you request an SSL Web Cert for your IIS OWA server and within that same hour of requesting the SSL Web Cert -installed it into IIS and then you configure a client to connect to the SSL web site you will get an invalid SSL web cert. Once I moved the client into the future by a day then the cert was considered valid. There must be a time window where the certificate will become valid. I wish I knew what that interval was between issue a web server cert and when it will become valid for the client.
RE: Discussion of OWA FBA Publishing article - 6.Oct.2004 4:19:00 PM
clynn
Thanks! Tom
Yes, Tom, I followed http://www.isaserver.org/tutorials/2004owafba.html to the letter.
Is it possible I need to do something with the Exchange server? Enable FBA? ****Edited**** I checked, and FBA is enable on E2k3. Compression was set to high, I switched to none.
When I try to log in to OWA I go to this page: https://SERVERNAME.DOMAINNAME.com/CookieAuth.dll?Logon
With this error: Unknown Request The request could not be resolved by the server.
I gotta be missing somthing minor.... [ October 06, 2004, 04:27 PM: Message edited by: clynn ]
RE: Discussion of OWA FBA Publishing article - 21.Oct.2004 11:45:00 PM
nshoemaker
OK I have set everything up according to the articles. I get a logon page and after entering my credentials, I get the dreaded 500 error. Help please!
RE: Discussion of OWA FBA Publishing article - 21.Oct.2004 11:51:00 PM
nshoemaker
To add more to what I was stating before here is the error I get.
error code: 500 Internal Server Error. The target principal name is incorrect. (-2146893022)
RE: Discussion of OWA FBA Publishing article - 22.Oct.2004 6:09:00 PM
wdennis
Hi all,
I'm having a problem publishing OWA via ISA FBA. Can you all take a look at my post on this forum, and if you have any possible solutions, post a response to it?
Link to my topic: http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=23;t=000237
RE: Discussion of OWA FBA Publishing article - 22.Oct.2004 11:36:00 PM
wdennis
Hey Nick,
I got the same error at some point with my setup. Turns out that I was using a different DNS name in the publishing rule than the one on the cert that was SSL-izing the connection (both are valid DNS names for the OWA server; the one in the cert is a CNAME, but I was using the A-record name in the rule.) Once I changed the publishing rule to have the same name as the cert's, all was well.
HTH, Will
RE: Discussion of OWA FBA Publishing article - 21.Nov.2004 2:00:00 PM
jimmyweston
Hi there,
I found the article very useful thanks. One additional question: we have a single Exchange server protected by a dual-homed ISA 2004 server. Is it possible - on the the same fixed IP address that OWA FBA is now published on, to publish Exchange for Outlook users via RPC over HTTPS. The problem - as I perceive it is that there will be 2 listeners needed on port 443 now. Is this possible? Thanks!
RE: Discussion of OWA FBA Publishing article - 29.Jan.2005 6:54:00 PM
come2
Dear Tom, thanks for your document! And thanks for HansĘ sharing! After I add A record for my website, then my OWA with SSL was worked!
Thank you all of you very much!
quote: Originally posted by tshinder: Hi Hans,
You bet! Yes, the name on the "To" tab has to match the name on the certificate. Otherwise, you see the name mismatching error.
Thanks! Tom
