need to enable IP routing
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> need to enable IP routing Page: [1]
need to enable IP routing - 5.Feb.2004 8:40:00 PM
eots
Where did MS hide the "Enable IP Routing" option that used to be available under Access Policies/IP Packet Filters in ISA2000?
I want to allow firewall clients behind ISA2004 to ping and traceroute remote addresses, but changing the network rule from NAT to Route doesn't work.
RE: need to enable IP routing - 6.Feb.2004 12:27:00 AM
Hi Eots,
You still need to make clients SecureNAT clients to use non-TCP/UDP protocols, because the Firewall client software only intercepts Winsock TCP and UDP requests.
(in reply to eots)
RE: need to enable IP routing - 6.Feb.2004 5:12:00 AM
ISA Server -> Configuration -> General -> Define IP Preferences -> IP Routing
(in reply to eots)
RE: need to enable IP routing - 6.Feb.2004 5:41:00 AM
Hi Dmitry,
Changing that value will not enable machines that are not enabled as SecureNAT clients, and only as Firewall clients, to use ICMP. The firewall client only handles Winsock TCP and UDP apps.
(in reply to eots)
RE: need to enable IP routing - 6.Feb.2004 2:57:00 PM
eots
Actually I had to change my ISA 2004 firewall policy to UNRESTRICED. I have 2 firewalls and I had no problem performing traceroutes through my ISA 2000 server. After changing the firewall policy I can now traceroute and ping remote addresses.
(in reply to eots)
RE: need to enable IP routing - 6.Feb.2004 3:40:00 PM
Hi Eots,
You can create a firewall policy that allows outbound ICMP echo request and inbound ICMP echo reply, that would be much more secure.
(in reply to eots)
