No connection to the AD/DC
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> No connection to the AD/DC Page: [1]
No connection to the AD/DC - 6.Feb.2004 5:59:00 PM
Raul E Jimenez
Hi there,
I have a Member Server of an AD domain.I used this server before with ISA 2000 and was able to browse my network and add Global Groups from the AD domain to the local groups of this Member server and asigned rights to it.
Since I have installed ISA 2004, there is not connectivity with the AD domain. I am aware of under System Rules severals of those contains policy definitions for this kind of access.
Do I have to create a Firewall Rule for this access?
RJ
RE: No connection to the AD/DC - 6.Feb.2004 7:21:00 PM
penrose.l@2college.nl
Hi Raul,
From your post I read that you were running ISA server 2000 on a member server , adding groups and users to this ISA server from the DC's ?
And now you upgraded and no longer have access to the DC ?
I would look in the Network rules ( not firewall rules ) from the LOCAL HOST to the INTERNAL NETWORK and put it on ROUTE instead of NAT.
Then make firewall rule of ALLOW all administrators all IP traffic all destinations to test.
Then if it works you know you can solve it and need to remove the rights. Then gradually increase security until it works ( or look up the correct port numbers [Smile] )
Kind regards,
Lex
(in reply to Raul E Jimenez)
RE: No connection to the AD/DC - 6.Feb.2004 8:54:00 PM
Raul E Jimenez
Hi Lex,
Yep, I am sure it will work, but if you see on the System Rules there are all the ports and protocols need it for the connectivity.
Are those System Rules disable? and if so, How we can enable?
Thanks for your help I will try it.
RJ
RE: No connection to the AD/DC - 8.Feb.2004 4:23:00 PM
Hi Raul,
The system policy elements that are not disabled are enabled by default. You can see which ones are disabled by the icon next to the System Policy element.
RE: No connection to the AD/DC - 8.Feb.2004 8:04:00 PM
Raul E Jimenez
Thansk Mr.Tom,
I got connectivity but have to create a specific Firewall Rule from Local Host to all Internals.
Those policies and rules that by default are disable, It is possible to enable? or the admin has to create a rule that match it?
RE: No connection to the AD/DC - 9.Feb.2004 3:59:00 AM
Hi Raul,
You can edit the firewall policy and change those policy elements. Right click on any of the rules and click edit system policy.
