rdp outbound from internal to perimeter net
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> rdp outbound from internal to perimeter net Page: [1]
rdp outbound from internal to perimeter net - 12.Feb.2004 4:49:00 PM
acorrea
I have a three legged template.. 1 internal and two perimeter networks..... I want to connect via rdp to a ts server in one of the perimeter based on user credentials in the AD.. So I have a rule that says internal-external(really perimeter) rdp protocol for user a.. Thinking this should work however it does not. The same rule that I setup denies 3389 outbound...
Any thoughts..
tks
angelo
RE: rdp outbound from internal to perimeter net - 13.Feb.2004 4:29:00 AM
Hi Angelo,
Have you created a routing rule between the two networks?
(in reply to acorrea)
RE: rdp outbound from internal to perimeter net - 13.Feb.2004 9:50:00 PM
penrose.l@2college.nl
hi ,
by default , users connecting to ISA are NOT ( ! ) authenticated. They are secureNAT clients ( or web proxies ). You need to install Firewall client on your workstation in order to be identified by the isa server. Once you're identified , the ISA server will allow the packetrule and you can RDP to server.
Check this in the monitoring tab of ISA.
Kind regards,
Lex Penrose
RE: rdp outbound from internal to perimeter net - 17.Feb.2004 4:42:00 PM
acorrea
Okay so if this only works for Proxy clients then (forgive the dumb question) how do I deny access for securenat or is there a way to auth the user prior to going out...
RE: rdp outbound from internal to perimeter net - 17.Feb.2004 8:35:00 PM
Hi A,
You can create a network set that includes the IP addresses of the hosts you want to control. Then use that in your "From" rule. However, for true security, you always need a client piece that sends credentials to the firewall. No firewall can authetnicate a user without a client piece. You should install the Firewall client software and configure the browsers as Web Proxy clients.
