MSN Messenger - Connection Closed
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> MSN Messenger - Connection Closed Page: [1]
MSN Messenger - Connection Closed - 1.Mar.2004 9:24:00 AM
Oliver A. B. Lewis
Hi, guys.....
I'm running isa 2k4 on clean 2003 Ent Server. I recently uninstalled 2k4 to put back ISA 2k but to check out a config. Now i have unistalled ISA 2k and put back on ISA 2k4.
The problem is now MSN messenger signs in then disconnects between 1 to 2 mins after signing in.
The active log shows connection closed.
Any suggestions?
Network Config:
SecurNat Client | -----> [ISA] -----> [Sygate ]
FireWall Client | -----> [ISA] -----> [Sygate ]
[3 Teamed]
RE: MSN Messenger - Connection Closed - 1.Mar.2004 9:26:00 AM
Oliver A. B. Lewis
Oops didn't finish...
[3 Teamed DSL Connections] ALL PORTS OPEN
on a WIN 2k3 box
(in reply to Oliver A. B. Lewis)
RE: MSN Messenger - Connection Closed - 1.Mar.2004 12:04:00 PM
Hi Pentium,
Are the three DSL connections connected to the Sygate machine?
RE: MSN Messenger - Connection Closed - 1.Mar.2004 2:28:00 PM
Oliver A. B. Lewis
Yep, all three are teamed at the machine. everything else works fine... infact internet access is very fast.
We found that this method was cheaper than the rainconnect method.
RE: MSN Messenger - Connection Closed - 1.Mar.2004 5:10:00 PM
Oliver A. B. Lewis
The result code looking at the active log says
Result Code: 0x80074e21
Error: 0x0
Any Ideas????
[Smile]
RE: MSN Messenger - Connection Closed - 1.Mar.2004 10:35:00 PM
Oliver A. B. Lewis
Funny though... I found that the problem is the same as in ISA 2K... I had to create a new Protocol description.
Name: MSN MSGR REAL
Primary ----> TCP OUTBOUND 1863
Secondary ----> TCP OUTBOUND 6891 -- 6900
Secondary ----> TCP INBOUND 6891 -- 6900
Secondary ----> TCP INBOUND 6901 -- 6901
(Not sure if it is absouletly neccessary)
Secondary ----> UDP 5004 -- 65535
You'd think they'd make it work for their own messenger [Big Grin]
RE: MSN Messenger - Connection Closed - 1.Mar.2004 11:10:00 PM
Hi Pentium,
RE: MSN Messenger - Connection Closed - 2.Mar.2004 12:18:00 AM
Oliver A. B. Lewis
Well said to say 3 hours lata its back to square 1...
Anybody else having this problem?
[Mad]
RE: MSN Messenger - Connection Closed - 2.Mar.2004 2:52:00 AM
Oliver A. B. Lewis
Arite i can safetly say its fixed.... Problem was at the Sygate server... Apparenlty it had something to do with persistent connections. I added an access rule and now everything is Good....
Smooth Sailing on 3 DSL connections...
RE: MSN Messenger - Connection Closed - 3.Mar.2004 2:26:00 PM
Hi Penitum,
Great! I'm going to need to try that Sygate method.
