FTP Access Policies
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> FTP Access Policies Page: [1]
FTP Access Policies - 1.Mar.2004 10:23:00 AM
nolsson
I canĘt get my FTP clients to work from the inside. The ISA Access Policies rule is set to allow FTP from internal to External for all users and I turned off the read only check box and the FTP filter is used.
IĘve tried the built in command FTP client and Internet Explorer from the internal clients and I get a time out in both cases.
RE: FTP Access Policies - 1.Mar.2004 12:00:00 PM
Hi Niclas,
What sites are timing out for you?
(in reply to nolsson)
RE: FTP Access Policies - 1.Mar.2004 3:57:00 PM
nolsson
It looks like its all sites, IĘve tried ftp.hp.com and ftp.sunet.se.
RE: FTP Access Policies - 1.Mar.2004 11:11:00 PM
Hi Niclas,
Are these Firewall, SecureNAT or Web Proxy clients?
RE: FTP Access Policies - 2.Mar.2004 11:23:00 AM
nolsson
Thanks for your patience here [Smile] , the clients are running as secureNAT clients.
When I run the built in FTP client it looks like thisą
C:\Documents and Settings\Administrator>ftp ftp.hp.com
> ftp: connect :Connection timed out
ftp>
In the ISA activity log I can se that the DNS resolution works fine, but the FTP looks something like this
Original Client IP
0.0.0.0
Server Name
HAN-TD-ISA
Transport
TCP
Source Port
3093
Processing Time
20922
Bytes Sent
0
Bytes Received
0
Result Code
0x8007274c
Cache Info
0x0
Error Info
0x0
Log Record Type
Firewall
Log Time
2004-03-02 08:33
Destination Host IP
192.6.234.8
Destination Port
21
Protocol
FTP
Action
Failed Connection Attempt
Rule
FTP Out
Client IP
10.0.1.133
Source Network
Internal
Destination Network
External
RE: FTP Access Policies - 3.Mar.2004 2:23:00 PM
Hi Niclas,
Not sure what the problem is. I tested it right now and it works fine.
You might want to uninstall and reinstall and try again.
RE: FTP Access Policies - 3.Mar.2004 2:58:00 PM
nolsson
Thanx, IĘll try that and get back with the result.
-N
RE: FTP Access Policies - 4.Mar.2004 12:11:00 PM
Hi Niclas,
