Need possible bug confirmed!
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> Need possible bug confirmed! Page: [1]
Need possible bug confirmed! - 17.Jan.2005 6:01:00 PM
Zapata
It would seem that ISA 2004 is not blocking external IP's after a deny rule is set for that/thoose IPs.
Example:
Deny, All Outbound traffic, from/listner (with a computer set containing the unwanted IP's), to Internal, Localhost (also tried ComputerSet anywhere)
After attending the Implementing ISA 2004 course the teacher confirmed that my setup was correct, he could also reproduce the problem.
Looking forward to any reply on this matter.
RE: Need possible bug confirmed! - 17.Jan.2005 6:19:00 PM
AbqBill
Hi Zapata,
It works for me here. Perhaps you should post your rules list and a sample of your log file that shows the traffic being allowed.
Bill
(in reply to Zapata)
RE: Need possible bug confirmed! - 17.Jan.2005 10:47:00 PM
Zapata
I'ts the No1 Rule with:
Deny, All Outbound traffic, all protocols.
From/listner (with a computer set containing the unwanted IP's)
To Internal, Localhost
This rule isn't getting processed and there is no evidence that this rule is being triggerd in the logs.
The Blocked ip however gets a seesion further down the ACL, for exanple HTTP publishing.
EDIT: Explanations
[ January 17, 2005, 10:49 PM: Message edited by: Zapata ]
RE: Need possible bug confirmed! - 19.Jan.2005 2:17:00 PM
penrose.l@2college.nl
export the rule to .xml and post it here.
RE: Need possible bug confirmed! - 25.Jan.2005 5:20:00 PM
dinodod
It may just be me but are these IP's initiating the connection or are these IP's that your clients are accessing?
If your clients are the ones accessing them, then your rules are reversed. You will need to block your clients from accessing the unwanted IPs, not have the IPs being blocked from accessing the Clients.
RE: Need possible bug confirmed! - 25.Apr.2005 7:59:00 PM
Zapata
Tried it both ways, ISA 2004 does not block to a server when you have the server publish rule beneath it, go figure!
Sorry for the delay in reply but notifications doesn't work for me.
/Z
