RDP to isa 2004
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> RDP to isa 2004 Page: [1]
RDP to isa 2004 - 1.Nov.2005 3:15:00 PM
edmund-edvinsen
Hi
I have a problem that I'm unable to solve.
I have one windows 2003 dc with Exchange and a member server (2003) with ISA 2004.
I'm unable to make a rdp connection to the isa server from anywhere.
I have tried to publish the isa server, and of cource i have enabled Remote Management in the Firewall Policy
Any suggestions??
eddie
RE: RDP to isa 2004 - 1.Nov.2005 3:30:00 PM
Hi eddie,
make sure that System Policy rule number 3 is enabled and that you added the proper Network Entities in the From tab. Of course, I assume you have enabled Remote Desktop in the My Computer System Properties (tab Remote).
(in reply to edmund-edvinsen)
RE: RDP to isa 2004 - 1.Nov.2005 3:38:00 PM
edmund-edvinsen
Hi and thanks for quick response.
System Policy rule 3 is enabled and I have added the whole subnet to the Remote Management computers (also tried to add a singel computer)
Remote Desktop is enabled at the ISA server
eddie
RE: RDP to isa 2004 - 1.Nov.2005 3:42:00 PM
Hi eddie,
OK. Then what is the ISA logging telling you?
RE: RDP to isa 2004 - 1.Nov.2005 3:51:00 PM
edmund-edvinsen
Port 3389 Protocol RDP
Action: Initiated connection - Rule: Allow Remote Management
And right after that;
Closed Connection
eddie
RE: RDP to isa 2004 - 1.Nov.2005 4:03:00 PM
Hi eddie,
so it looks that the access is indeed allowed by the ISA server but that there is something wrong with the Remote Desktop settings instead. Do you get a login screen?
What's the Result Code, Error Information in the logging? Also, do you see some Bytes Sent and Bytes Received.
Also, try a telnet to the RDP listener with the following command 'telnet ISA 3389'. The connection should succeed.
[ November 01, 2005, 04:04 PM: Message edited by: spouseele ]
RE: RDP to isa 2004 - 1.Nov.2005 4:29:00 PM
edmund-edvinsen
Hi Stefaan
In the log I can only see Initiated connection and right after that Closed Connection....
I have tried to Telnet to port 3389 with no result - seems to me that 3389 is not listening?
I can ping the ISA server ( I have allowed ICMP in remote Management)
I have also tried to publish terminal services on the ISA server
eddie
RE: RDP to isa 2004 - 1.Nov.2005 4:46:00 PM
Hi eddie,
What do you mean by that? Don't you see those fields? If not, add them to the view.
What's the result of the command netstat -ano | find ":3389". It should be something like
code:
  netstat -ano | find ":3389":
TCP 0.0.0.0:3389 0.0.0.0:0 LISTENING 2712
[ November 01, 2005, 05:56 PM: Message edited by: spouseele ]
RE: RDP to isa 2004 - 1.Nov.2005 7:17:00 PM
LLigetfa
Why and how did you try to publish the ISA server? Is it your intention to access it via RDP from the outside? Did you specify the NICs to listen on in the Terminal Services configuration?
RE: RDP to isa 2004 - 2.Nov.2005 4:20:00 PM
edmund-edvinsen
Hi again
In Terminal server Config and RDP-TCP properties all network adapters was selected.
I changed it to the internal adapter and all works fine.
Stefaan:
netstat -ano showed no rdp at port 3389 before I changed the setting.
Thank you both for the help
eddie
RE: RDP to isa 2004 - 3.Nov.2005 1:32:00 PM
Hi eddie,
good to hear you have it working and thanks for the follow up! [Smile]
RE: RDP to isa 2004 - 14.Nov.2005 5:23:51 PM
dezaer
Hi I had the same probleme thanks for you rhelp !
(in reply to spouseele)
RE: RDP to isa 2004 - 27.Dec.2005 11:53:24 AM
markkpa2
Mee too had the same problem...very strange problem though ;)
BUT anyway THANX!
(in reply to dezaer)
RE: RDP to isa 2004 - 7.Feb.2007 7:23:47 PM
ynguyen
I have got the same problem but able to find out why.  It used to work before.
I have:
1. Enabled RDP in the policies.  Accept from my machine (management computer...)
2.Just created a new server publishing rule to publish port 3389 incomng to the internal interface.
3.  My machine in in the from section in the rule
4.  Restarted the service (also the server)
I can ping the machine from my computer.
I can't telnet to the ISA in ternal on port 3389
I enabled the qury the saw, Intiated connect...then closeed connection straight afterward.
This is driving me nut
RE: RDP to isa 2004 - 16.Jun.2009 9:49:33 AM
bencjedi
I just installed my first ISA server (2006) and figured out how to do this. I created a brief 2-page tutorial with screenshots, but this site doesn't allow attachments (?). Anyhow, here is the text of how to do it:
By default you cannot remote into the ISA server. Make these changes to be able to do so:
Create a Firewall Policy Rule to allow RDP (Terminal Services) Server and RDP (Terminal Services).
Set it like this:
To: Internal
all users
Now click on ‘Edit System Policy’ and go to Remote Management section, then 'Terminal Server' and click the 'From' tab. Add in ‘Internal’ network for 'This rule applies to traffic from these sources'.
On any workstation in your internal network (as specified on the ISA server), you should be able to remote desktop into the ISA server now.
RE: RDP to isa 2004 - 16.Jun.2009 1:47:59 PM
Never create a rule from Internal to Internal !!
Check this article, you only need to edit a system policy : Administrating ISA Server 2006 Remotely Using MMC and Remote Desktop Connection
Windows Expert - IT Pro MVP
(in reply to bencjedi)
RE: RDP to isa 2004 - 16.Jun.2009 3:35:44 PM
bencjedi
Thank you
(in reply to elmajdal)
RE: RDP to isa 2004 - 16.Jun.2009 4:40:36 PM
You are Welcome.
Tarek
RE: RDP to isa 2004 - 26.Jul.2010 5:29:54 AM
AymanOZ
THANKS
ORIGINAL: ynguyen
I have:
(in reply to ynguyen)
Post #: 19
