WINS Proxy and/or 0xc0040014 ?
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> WINS Proxy and/or 0xc0040014 ? Page: [1]
WINS Proxy and/or 0xc0040014 ? - 10.Sep.2004 5:49:00 PM
grinn253
Hello again! "[Smile]"
Appears that our ISA 2k4 setup may almost be close to completion. Here is the setup:
External NIC = 128.208.125.85 /26
Internal NIC = 128.208.125.19 /26
Clients NIC = 192.168.125.100 /24
Every NIC for ISA is on its own network, we have put the client workstations on the 'Client network' and the servers on the 'internal network' So far traffic/policy is working pleasureful between the internal/external/client networks.
Except that when client workstations broadcast what i believe is a name query to 192.168.125.255, ISA denies the conection (port 138) with a result code of:
0xc0040014 FWX_EFWE_SPOOFING_PACKET_DROPPED
What then happens is when viewing a file such as a .doc that is stored on a network file server, the connection is lost (ISA produces the 0xc0040014 code) and Word, asks the user to reconnect to the server or exit.
So, I created a Lmhosts file for workstations that #PRE and #DOM the fileservers and also has \0x1b \0x1d entries for a DC.
The workstations still wanted to broadcast (bypassing lmhosts file?) but nbtstat -c shows that indeed the lmhosts file is being parsed correctly (determined by life -1)
Finally, would someone be kind to let me know how isa can allow the 192.168.125.255 broadcast traffic? I'm going to regedit ISA to enable it as a WINS Proxy to see if that helps, in the mean time, thank you for your time! "[Razz]"
Edgardo
p.s. a good article on WINS Proxy: "[Wink]"
WINS Proxy
[ September 10, 2004, 05:51 PM: Message edited by: grinn253 ]
RE: WINS Proxy and/or 0xc0040014 ? - 13.Sep.2004 7:48:00 PM
grinn253
Setting ISA as WINS Proxy did nothing to accept the broadcasts to 192.168.125.255.
I'm also noticing:
0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED
when clients 192.168.x.x. are accessing internal 128.208.125.x
[Embarrassed] However by changing the broadcast address in the registry to 128.208.125.255, ISA passes the broadcasts [Big Grin] and the client workstations appear to hold their connections to MS Word documents longer. Originally was timing out ~5 seconds to 5 minutes. Now seems to time out more often when saving, rather than just during typing, or viewing of the file.
I'm now going to try editing keepalivetime & sessionkeepalive time in the registry on client workstations to see if it will keep communications with ISA (when MS Word/documents are open) active.
Goodbye,
Edgardo
(in reply to grinn253)
RE: WINS Proxy and/or 0xc0040014 ? - 14.Sep.2004 7:55:00 PM
penrose.l@2college.nl
Hey Grinn,
Let me guess you have a NAT relationship ?
check this out. I spent 4 weeks to find where this error originates.
KB 301673 ű ˘You Cannot Make More Than One Client Connection Over a NAT Device÷ describes the issue. See http://support.microsoft.com/default.aspx?scid=kb;en-us;301673 for more details
This should definately be a sticky ( tom ? ) because it's a big problem with ISA.
Lex P.
RE: WINS Proxy and/or 0xc0040014 ? - 15.Sep.2004 4:29:00 AM
Hi Lex,
Why not just disable NetBIOS on the clients and use DNS? Or how about just using a WINS server to get rid of the broadcasts, and finally, disable the dreaded browser service on all hosts.
RE: WINS Proxy and/or 0xc0040014 ? - 15.Sep.2004 4:31:00 AM
Originally posted by Lex Penrose:
Hey Grinn,
Lex P.
Hi Lex,
All Internal networks should be routed, so that NAT issue isn't an issue. Are you NATing between internal networks? If so, why? There are a lot of disadvatages and few if any advantages.
RE: WINS Proxy and/or 0xc0040014 ? - 15.Sep.2004 7:22:00 PM
grinn253
Hello, yes disabling NetBIOS on the clients also appears to work, however a machine we connect to via trust, is still on NT 4.0 so traffic to that machine isn't able to only use port 445 [Frown]
Browser service is already disabled on client workstations, WINS server already in place as well.
Lex, thanks a lot for your link! So far looks good, i'll relay a little more when a little more tests are run.
Edgardo
RE: WINS Proxy and/or 0xc0040014 ? - 16.Sep.2004 10:45:00 PM
hi ,
I remember something deep in my head that disabling netbios is bad. Something with GPO processing if I remember well.
anyway , if it helps it helps [Smile]
LexP
ps : NAT = for publishing other than websites internally on the ISA
