RE: I WILL PAY YOU TO HELP ME FIX my PERIMETER ISA 2004 network
RE: I WILL PAY YOU TO HELP ME FIX my PERIMETER ISA 2004... - 8.Mar.2005 5:12:00 AM
WyldWolf
Sorry Tom I misunderstood, I thought he was trying to publish servers which you probably wouldn't want to do with all public addresses. So you should be able to simply re-cable.
But evps, as I saw in the route table you posted was a mis-masking as your subnet of servers was masked the same as the block of IP addresses on the external ISA nic, hence it won't know how to route the traffic. If you fix that so that the public server IP's and your external ISA nic are masked properly (and recable) you should be good to go! [ March 08, 2005, 05:14 AM: Message edited by: WyldWolf ]
RE: I WILL PAY YOU TO HELP ME FIX my PERIMETER ISA 2004... - 8.Mar.2005 2:45:00 PM
evps
Tom says "and the upstream router is configured with the route to that block"
The ISP says "We don't add routes to our upstream routers"
Now what?
RE: I WILL PAY YOU TO HELP ME FIX my PERIMETER ISA 2004... - 9.Mar.2005 1:59:00 AM
quote: Originally posted by WyldWolf: Sorry Tom I misunderstood, I thought he was trying to publish servers which you probably wouldn't want to do with all public addresses. So you should be able to simply re-cable.
Hi WW,
But that's the cool thing, you can publish servers even you configure a route relationship between the source and destination Network. You couldn't do that with ISA 2000.
Try it out, its cool!
HTH, Tom
RE: I WILL PAY YOU TO HELP ME FIX my PERIMETER ISA 2004... - 9.Mar.2005 7:35:00 PM
tcgeorge
"Should I have plugged internet directly into the ISA box's External NIC?" - Absolutely.
You should have your internal facing nic plugged into the same switch as all of your other pcs/servers on your network.
You should have you external facing nic plugged directly into your internet connection.
You should have your DMZ facing nic plugged into another switch with those servers that you want the general public to have access to.
I do agree with WW that your subnet mask does not appear correct for a public address set. Verify your mask settings with what your ISP provided to you.
