ISA 2004 to PIX ipsec tunnel
All Forums >> [ISA Server 2004 Firewall] >> VPN >> ISA 2004 to PIX ipsec tunnel Page: [1]
ISA 2004 to PIX ipsec tunnel - 31.Mar.2004 11:46:00 PM
zvakil
Hi There
Has anyone seen an article that talks about how to configure an ISA 2004 to PIX ipsec tunnel.
Where do you set the IKE Phase1 and Phase 2 parameters?
Zubin
RE: ISA 2004 to PIX ipsec tunnel - 1.Apr.2004 3:26:00 AM
ClintD
I'm assuming you mean on ISA. You need to create a "Remote Site Network" - once this is created, under the "Connection" tab, you'll have an "IPsec Settings" button that will give you the Main and Quick Mode settings.
I have done this with PIXOS 6.3.1 and it works fine.
(in reply to zvakil)
RE: ISA 2004 to PIX ipsec tunnel - 1.Apr.2004 5:38:00 AM
andifur
I have worked with a broad range of cisco ipsec VPNS from Routers to 3000 series concentrators to PIX's. Getting them to play together is a piece of cake. Through a Windows server into the mix and you cake turns to molasis! I have everything setup correctly in ISA04. I am getting the security logs about main mode established and quick mode established. I am assuming Phase I and II?? When I go to ping to any remote system from the ISA box, I get Negotationg IP Security, over and over and over. If I do it from a box behind the ISA I get reqest timed out. I have tried this to a router, PX and a 3005 concentrator all without luck. If I remove the ISA and place a simple 831 router in its place the VPN is up within seconds. I have checked my settings 100x times and still nothing. Any suggestions????
RE: ISA 2004 to PIX ipsec tunnel - 1.Apr.2004 6:25:00 AM
ClintD
If you PING from the ISA box, what filter do you have on the remote device that matches ISA's filters?
When you create the "Remote Site Network", it creates 2 Quick Mode filters
Local Subnet to Remote Subnet
ISA's External IP to Remote Subnet
If you have Win2003, you can use NETSH IPSEC DYNAMIC SHOW QMFILTERS ALL to see these filters. If you have Win2000, use NETDIAG /test:ipsec /v /debug to see the filters.
You need to make sure that there are matching filters on ISA and matching ACLs on the router or PIX.
When I tested interop with my PIX, I tried PINGing from ISA but couldn't get IPsec to come up until the PIX had a filter added that explicitly listed the ISA Servers external IP address (which makes sense because of a filter mismatch).
The behavior of ISA PINGing the remote subnet and receiving "Negotiating IP Security" is most likely due to a filter mismatch.
The client timing out is most likely due to not having a Firewall Policy Access Rule defined in ISA that allows traffic to pass from the ISA's Internal Network to the Remote Site Network. What rule have you created to allow this? It can also be caused by IPsec negotiations failing between the endpoints.
[ April 01, 2004, 06:35 AM: Message edited by: ClintD ]
RE: ISA 2004 to PIX ipsec tunnel - 2.Apr.2004 6:16:00 PM
zvakil
You mentioned on another post that Microsoft internally has an white paper decribing an ipsec tunnel between a pix and isa2004. Would you happen to have seen a "beta" copy of that paper?
Zubin
RE: ISA 2004 to PIX ipsec tunnel - 3.Apr.2004 10:22:00 PM
Hi Zubin,
I don't have a cop[y of it, but I know who wrote it [Smile]
It should be released on the MS Web site by the time the product RTMs.
