Mike_Gregory
I used many different methonds, one I like, using GRC.com's shields up. I have also scanned my system from external sources using port scanners such as Languard network scanner, and a few others.
Anyway... I got my router! And I have it setup and everything, (except for my site) is working PERFECTLY... ALthough I am not using ISA server at the moment.
I got NAT going and DHCP, while using a static IP for my DSL connection. So far everything is working perfectly. I am only having one problem, perhaps someone can help.
If you go to my website, or anyone, it brings up a username and pass request to access my site, I am pretty sure it is the router, and I can't find where to turn this off. I did a show web in my router and web is enabled, on port 80, and accepts a connection from any host. But I am not exactly sure if this is the "web" I want. For some reason I got a strange preminition it is some sort of web-based managment for my router, however I am not sure. I have been unable to contact tech support since I don't get home in time, but I will be calling from work tomorrow I think. But if anyone knows exactly what the problem is let me know.
As for ISA server. How do you suggest I setup my infrastructure. The main reason I got this router, was so that everyone on my network, could have internet access at all times, therefor not needing a server to share the connection, and when the server is down, no one can access. Getting the router has fixed that issue. Yet I still want to use ISA server. Yet I do not know how I wanna set it up.
I will explain my current network infrastructure tomorrow (im tired right now), I may just explain it in words, or if anyone uses MS Visio I may make a diagram for ya'll.
Anyway basically I wanna know if I should have my router connect directly to my ISA server, and have my ISA server share the internet connection, this is how I really want to do it, but I must be sure this server will be reliable, because I do not want to hear any more complains from members of this house (lol... every time the server's down "DAMN IT! I cant get my e-maili!... sad). If possible, I'd like my router to connect to my switch, (as it is now) and also have my ISA sharing. But I don't know if this is possible having 2 sources hosting one internet connection. Reason for this if my ISA server goes down, or needs restarted, users can just go through the switch, to the router, instead of the proxy. But this all seems kinda complex... Anyway I am tired and don't wanna talk anymore. Please opinionate on what you all think.
Thanks, Mike
