RE: IM going out through ISA
RE: IM going out through ISA - 19.Dec.2002 4:03:00 AM
Status: online
Hi Mike,
Arrgh! Just when things seem to be coming together.
RE: IM going out through ISA - 19.Dec.2002 11:56:00 AM
kb5oze
Hi Dr. Shinder, It could be worse. But the important thing is that it works. Something else I found out last night is that if you call up net meeting from IM, IM tries to use the computer's local IP address (both of them). If you are behind a router, this will not work. If you just use net meeting itself to make the call (with NM configured to use the ISA), it works fine. Just one more glitch to add to the list.
Have a great day!
Mike
RE: IM going out through ISA - 21.Dec.2002 3:52:00 AM
kb5oze
Now that I have thought about it, I also found that even though Netmeeting is configured to use the gatekeeper, IM doesn't see that and seems to try a direct connect as opposed to using the gatekeeper. I will look further into this.
Mike
RE: IM going out through ISA - 24.Dec.2002 4:42:00 AM
CodingStudios
I am using IM internally with the same original problem in this posting. I have my clients setup as secureNAT and web proxy and the IM works fine internally. My exchange server is a seperate server/domain from the ISA server. Exchange is setup as a SecureNAT. Make sure that you have a DNS server with the _rvp record setup. Without that, none of my clients could authenticate.
