RE: Can't access Terminal Server behind ISA
RE: Can't access Terminal Server behind ISA - 21.Dec.2003 10:57:00 AM
tolvar
The internal connection error occured when I published the Terminal Server, after i removed the rule I could then connect again but only from the workstation.
I've now gone into Terminal Services Configuration and selected the internal NIC running ip 192.168.0.1 and this does appear to now work locally, I've yet to try the connection from a remote site.
RE: Can't access Terminal Server behind ISA - 21.Dec.2003 8:31:00 PM
Hi tolvar,
after binding the TS on the internal interface, check out that only a listener is installed on the internal IP address '192.168.0.1' with the command netstat -an | find ":3389". If that's OK, create then your server publishing rule.
Keep in mind that from an internal station you should always contact the TS on ISA on IP address '192.168.0.1'. However from an external host you will have to use the external IP address you have published the TS on.
HTH, Stefaan
RE: Can't access Terminal Server behind ISA - 21.Dec.2003 10:01:00 PM
tolvar
Hi
ok, I created a sever publishing rule and this is what i see after running a netstat -an
TCP 192.168.0.1:3389 0.0.0.0:0 LISTENING TCP 192.168.0.1:3389 192.168.0.8:1095 ESTABLISHED
does this look ok?? [ December 21, 2003, 11:39 PM: Message edited by: tolvar ]
RE: Can't access Terminal Server behind ISA - 21.Dec.2003 11:33:00 PM
tolvar
Hi Stefaan
Just a quick note to thank you for your patience and time, many thanks.
Tolvar.
