RE: Anyone can get to the internet
RE: Anyone can get to the internet - 24.Jan.2004 8:42:00 PM
ralphyost
Hi STefan: There were two typos, but there were also two entries that are correct. 1. This entry above is CORRECT: NetworkDestination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.1.2 192.168.1.1 1 2. The Ip addresses in IPCONFIG/ALL you pointed out were incorrect. 3. Default Gateway at the bottom is correct 192.168.1.2. Here is the revised data: Results of ipconfig /all: Windows 2000 Configuration Host name: acrmdell primary DNS: acrm.local NODE type: hybrid IP routing enabled: yes WINS Proxy enabled: no DNS Suffix Search List: acrm.local
Ethernet Adapter Internal NIC: DHCP Enabled: no IP Address: 192.168.16.2 subnet mask 255.255.255.0 Default Gateway: DNS Server : 192.168.16.2 Primary WINS Server 192.168.16.2
Ethernet Adapter External NIC Internet: DHCP Enabled: no IP Address: 192.168.1.1 subnet mask 255.255.255.0 Default Gateway: 192.168.16.2 DNS Server : 24.40.32.33 Primary WINS Server 192.168.16.2
Result table of ROUTE PRINT (remember that I was on a VPN to obtain this): Actvie Routes: NetworkDestination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.1.2 192.168.1.1 1 68.46.80.6 255.255.255.255 192.168.1.2 192.168.1.1 1 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 192.168.1.0 255.255.255.0 192.168.1.1 192.168.1.1 1 192.168.1.255 255.255.255.255 192.168.1.1 192.168.1.1 1 192.168.16.0 255.255.255.0 192.168.16.2 192.168.16.0 1 192.168.16.11 255.255.255.255 192.168.16.49 192.168.16.49 1 (my VPN) 192.168.16.49 255.255.255.255 127.0.0.1 127.0.0.1 1 192.168.16.255 255.255.255.255 192.168.16.2 192.168.16.2 1 224.0.0.0 224.0.0.0 192.168.1.1 192.168.1.1 1 224.0.0.0 224.0.0.0 192.168.16.2 192.168.16.2 1 255.255.255.255 255.255.255.255 192.168.1.1 192.168.1.1 1 Default Gateway 192.168.1.2 Persistent Routes: NONE
- content of the LAT: Only one: 192.168..16.0 to 192.168..16.255
This is a Small Business Server 2000. It has its own DHCP server and DNS server function along with ISA server on the same machine. Thanks R.
RE: Anyone can get to the internet - 24.Jan.2004 9:01:00 PM
Hi ralphyost,
I assume there are still some typo's: - External NIC: Default Gateway: 192.168.16.2 - LAT: 192.168..16.0 to 192.168..16.255 (extra dots)
If the above are typo's then your interface settings and the LAT seems now to be correctly configured!
Next, thoroughly test out the DNS resolving of external FQDN's. Does it work? It is of no use to test further as long a you don't have a stable DNS infrastructure.
Also, do you see any ISA related errors/warnings in the Event log?
HTH, Stefaan
RE: Anyone can get to the internet - 24.Jan.2004 9:21:00 PM
ralphyost
StefaN: Good news: Its all working now ! Yes, that was a type. It should have been 192.168.1.2 as you noticed correctly. When I deleted the extra LAT entries and then tried the internet from the server, it didnt work. After a few minutes, I went back and checked the browser settings on the server. It was not configured to use the proxy. Once I did that, it worked fine. Then I VPNed into a workstation (I use PCAnwywhere) and logged on LOCALLY, without authenticating to the server. Now I cant get out ! This is what I have been working for. Thanks ! R.
RE: Anyone can get to the internet - 24.Jan.2004 9:25:00 PM
ralphyost
All: I want to express my sincere appreciation for all the help you all have provided me in the last week or two. You have helped me not only to solve my ISA Server problem, but also have helped me to learn a lot about some aspects of ISA Server that I would not have otherwise done.
I want you all to know that your kindness and effort has not gone unnoticed. Thank You all. May the Lord richly bless you, as in Numbers 6:24-26. Numbers 6:24-26 The LORD bless thee, and keep thee: The LORD make his face shine upon thee, and be gracious unto thee: The LORD lift up his countenance upon thee, and give thee peace.
R.
