Sharepoint WSS
All Forums >> [ISA Server 2004 Firewall] >> Logging and Reporting >> Sharepoint WSS Page: [1]
Sharepoint WSS - 10.Aug.2004 7:03:00 AM
Ivanbrebner
Has anyone configured a way to have the reports published to a sharepoint server?
I was thinking about simply using the ADO "[Eek!]" connection to the MSDE on the ISA Server to make some filtered Reports using Office Pivot tables via Office Web Components but that can be very heavy.
Any ideas?
Ivan Brebner
RE: Sharepoint WSS - 11.Aug.2004 12:26:00 AM
Hi Ivan,
You can publish them to any share that's reachable to the ISA firewall. Won't that work?
(in reply to Ivanbrebner)
RE: Sharepoint WSS - 11.Aug.2004 1:42:00 AM
Ivanb
BTW ISA 2000 helped me out a few times. Almost as much as the Forum [Razz] . Yes you are right I can make a share, and use the file link portal Web Part. I was kind of hoping to publish directly so that I could archive inside the Database of WSS rather than a flat file out side. Not a problem, I am sure that I may be able to make this work a bit better, for now I will do the above mentioned. If it could send as an attachemnt the entire report then I could use the Public Folder from Exhchange 2000/3 that you can forward to a document area but this looks like it only send the link.
All good though and thanks for the reply and hope all is well.
IvanB
RE: Sharepoint WSS - 11.Aug.2004 12:23:00 PM
Hi Ivan,
Sounds like a plan.
Thanks for the kind words about the book!
