In ISA2004St replace path to storage ISA Firewall and Web Proxy logs from install path to another. Restart server. And now i have problem with query to my logs. If Log time=Live all OK. But when i change Log time=last hour or any other server show message "The query stopped because an error occured while it was running". Windows logs is empty. Reports works normal. What can i do? Thanks.
I'm getting the same thing. In addition, I'm running ISA SP1 and W2K3 SP1. However, it seems related to the size of the queried data - the longer the time period queried, the more likely it is to error out. Is there a timeout setting somewhere?
I am getting this too. I had switched from MSDE format to file format for a couple of days to evaluate a 3rd party reporting tool. Now I can't query anything prior to the temp change. I thought If I formed the query with dates before the change, that might work, but I can't query any dates from the MSDE files dates before the change happened. Last 24 hours query is working okay dates, between queries from after the changes are also okay. Problem is, management wants a "last two weeks" log on someone today. Are the logs corrupt, or what? Please help!
