If you don't want to see "unidentified IP traffic" create a protocol definition for that protocol and the name you give the protocol definition will appear in the log files.
When this occurs the known software should be using the newly defined port, but ISA displays an incremented port number instead.
When assigning a name to the port number, the new name for the defined port number is not displayed in the logs. Instead another unidentified port is found which is usually only one or two port numbers away from the newly defined port.
The more ports I define the higher the unidentified port number goes. It's not like I have a ton of other undefined port numbers coming up in the log, I have none.
