Turn off cache
All Forums >> [ISA Server 2004 Cache] >> General >> Turn off cache Page: [1]
Turn off cache - 5.Nov.2004 7:30:00 PM
pr0nd3xtr
Is there any way to just turn off the cache feature? I am building a website and I want the web server logs to reflect the originating IP, not the ISA server IP. I have tried creating cache rules to that host, and have the cache size set to 0. This will be rather important in the long run, as I will need to log and retain archives of everything that accesses the web server.
Thanks.
Matt
RE: Turn off cache - 6.Nov.2004 1:07:00 AM
Johno
Hi Matt
From what I see the cache is off by default during install.
If you open the cache configuration window with the task pane available there is a disable cache link which turns off cache and sets it to zero.
I'm no expert by any means but maybe that isnt the way to acheive the web server logs that you require? Wouldnt ISA server itself create those logs?
Sorry I'm not much help [Wink]
Johno
[ November 06, 2004, 01:13 AM: Message edited by: Johno ]
(in reply to pr0nd3xtr)
RE: Turn off cache - 6.Nov.2004 4:30:00 AM
Ara.A
It is off by default install. If you are looking to log your incoming web server visit, use IIS feature∆s not the ISA one
If you host more than one site, make sure in publishing rule, the click that says send original host header is selected
[Wink]
RE: Turn off cache - 7.Nov.2004 8:33:00 PM
pr0nd3xtr
The cache is turned off, but the only ip address I am seeing on the webserver logs is the ISA server. As it sits now though, I dont have a publishing rule, I just have it set to allow port 80 to that particlar ip of the web server.
Thanks for the replies.
[ November 07, 2004, 08:33 PM: Message edited by: Matt Bullock ]
RE: Turn off cache - 7.Nov.2004 8:38:00 PM
Ara.A
Create publishing rule and there is a click when you publish a web server that says send original host header. That should do the job
Never use dumb port 80 forwarding to a web server [Wink]
[ November 07, 2004, 08:40 PM: Message edited by: Ara ]
RE: Turn off cache - 9.Nov.2004 12:24:00 AM
pr0nd3xtr
The same option to send the original header is available with my port forwarding rule under Protocols --> Filtering --> Configure HTTP. Is this supposed to work in the same manner as with a publishing rule?
