RE: Discussion about SSL Tunnel Port Range Article
All Forums >> [ISA Server 2004 Cache] >> General >> RE: Discussion about SSL Tunnel Port Range Article Page: <<   < prev  1 [2]
RE: Discussion about SSL Tunnel Port Range Article - 13.Jul.2005 6:53:00 AM
jnw
Hello!
Some small quetion about article. Author wrote:
"1. A Web client on an ISA Firewall Protected Network makes a request for an SSL object from a Web server on the Internet by entering the following in the Address bar of the Web browser:
https://URL_name
2.When the user sends the request, the following is sent to port 8080 (the port on which the Web listener listens for outbound connections) on the ISA firewall:
CONNECT URL_name:443 HTTP/1.1"
But if client configures IE to use proxy for https like ISA_name with port 443 and enter in the Address bar:
https://URL_name:443
is this request sent to port 8080 on the ISA firewall too? Or to port 443?
Many thanks.
[ July 13, 2005, 08:19 AM: Message edited by: jnw ]
Post #: 21
RE: Discussion about SSL Tunnel Port Range Article - 19.Jul.2005 2:44:00 PM
234234dvdfvdfvasd
I just upgrade ISA server 2004 from 2000 and I am having problems accesing some https websites like banks. I disable the proxy on my IE and everything works fine. I think the solution is to add ports to the SSL just as the article says but I don't know which port should I add. How can I know the port that I need?
Thanks a lot.
Homero
Post #: 22
RE: Discussion about SSL Tunnel Port Range Article - 2.Aug.2005 6:11:00 AM
Carlo.Olivieri
The isatools.org site isn't available. [Frown]
It seems that isatools.org is not registered in the DNS systems ...
The authoritative name servers (NS1.JALOJASH.ORG & NS2.JALOJASH.ORG) seems down ...
What happened? Is there somewhere else I could get the scripts from?
TIA
Carlo
Post #: 23
RE: Discussion about SSL Tunnel Port Range Article - 2.Aug.2005 2:39:00 PM
Hi Carlo,
the site isatools.org is up and running at this moment! [Wink]
Post #: 24
RE: Discussion about SSL Tunnel Port Range Article - 23.Aug.2005 3:33:00 PM
There's another script that does this at
http://www.isascripts.org
  Post #: 25
RE: Discussion about SSL Tunnel Port Range Article - 8.Sep.2005 6:19:00 PM
jklick
Does this apply to ISA 2000 as well?
Post #: 26
RE: Discussion about SSL Tunnel Port Range Article - 22.Sep.2005 12:35:00 PM
amazone
can I use this tool for ISA2000 with only in Web Proxy mode???
Amazone
Post #: 27
RE: Discussion about SSL Tunnel Port Range Article - 12.Oct.2005 12:55:00 PM
gpmissi
How to made the same on ISA 2000?
Regards
[ October 12, 2005, 12:56 PM: Message edited by: gpmissi ]
Post #: 28
RE: Discussion about SSL Tunnel Port Range Article - 1.Nov.2005 4:57:00 AM
rudacunha
When I enter in sites thus
https://www.site.com:2020
Ai of the error but when I enter in sites thus
https://www.site2.com
It functions perfectly as to decide this?
Post #: 29
RE: Discussion about SSL Tunnel Port Range Article - 3.Nov.2005 9:55:00 AM
rudacunha
Nobody can help!
It is urgent.
Post #: 30
RE: Discussion about SSL Tunnel Port Range Article - 30.Nov.2005 2:04:15 PM
jonathanc
See http://support.microsoft.com/?kbid=283284 for ISA 2000 script
J
(in reply to rudacunha)
Post #: 31
RE: Discussion about SSL Tunnel Port Range Article - 3.May2006 3:56:09 PM
bank2640
I hope someone will see this since it's an older article.
This fix works great for SSL sites. How about a non SSL site using a different port? One of my users need to connect to a standard http site on port 8088. I added port 8088 using the script, but it didn't work. I figured it wouldn't since this fix is only for SSL. Does anyone have a fix for non-SSL sites?
Any help would be great!
Mike
(in reply to jnw)
Post #: 32
RE: Discussion about SSL Tunnel Port Range Article - 2.Jan.2007 8:14:07 AM
ORIGINAL: tshinder
This thread is for discussing the article on extending the ISA firewall's SSL tunnel port range over at http://isaserver.org/articles/2004tunnelportrange.html
[ November 29, 2004, 07:05 AM: Message edited by: tshinder ]
The website of Jim has been redesigned, and the old links to download the tools in you article is not valid anymore.
So please update the article with the new links to download the tools :
ISA TPRE : http://www.isatools.org/tools/ISAtrpe.zip
ISA Tunnel Port tool : http://www.isatools.org/tools/isa_tpr.js
Tarek
Post #: 33
RE: Discussion about SSL Tunnel Port Range Article - 22.Jul.2007 12:35:16 PM
network2004
Hi
I Tray To Acsses To trendmicro console that is using (https//192.168.0.1:4343) I receve this errore
Error Code: 502 Proxy Error. The specified Secure Sockets Layer (SSL) port is not allowed. ISA Server is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. (12204)
IP Address: 192.168.0.2
Date: 7/22/2007 8:16:24 AM
Server: net-server.XXXXXXX.com
Source: proxy
nay one help me
(in reply to bkhorsa)
Post #: 34
RE: Discussion about SSL Tunnel Port Range Article - 7.Aug.2007 12:55:03 PM
mike999
I am getting an error when trying to access a website / java app.
The website is https://www.53.fx.com
The text of the error is:
There was an error reported when connecting to the server for Client
Reported error: access denied (java.net.SocketPermission <<servername.domain.com:8080 connect, resolve)
Retry login at this server?
Initially I thought this just required me to add port 8080 using the method described in the article.  However, after doing so I still get the same error.  (Does the ISA server need to be restarted for the port 8080 to work? - I did not do this yet)
Post #: 35
RE: Discussion about SSL Tunnel Port Range Article - 19.Feb.2008 7:55:20 AM
shashig
Dear Tom,
I wonder if you could help me please.  I understand this article is for ISA 2004.  Is there any way to add SSL Tunnel Port on ISA 2000 Server?
Thanking you in anticipation,
Best Regards,
Shashi
Post #: 36
RE: Discussion about SSL Tunnel Port Range Article - 21.Feb.2008 4:02:12 AM
shashig
Dear Tom,
Best Regards,
Shashi
Post #: 37
RE: Discussion about SSL Tunnel Port Range Article - 21.Feb.2008 6:11:16 AM
Same tools.
Source : http://www.isatools.org/tools.asp?Context=ISA2000
(in reply to shashig)
Post #: 38
RE: Discussion about SSL Tunnel Port Range Article - 11.Apr.2008 4:27:34 PM
cjdjackson
Is this forum still available to assist with a port range problem?  I posted an assist in the ISA Firewall General forum in regards to Citrix ICA protocols.  Thanks.
CJ
Post #: 39
RE: Discussion about SSL Tunnel Port Range Article - 11.Jun.2008 8:59:23 PM
machamma
Hi guys!
I use Isa 2006 and I am having problem with the following site:
Website: https://wwwt.connectmed.com.br/connectivity
Looking at the log it shows SSL-Tunnel protocol, port 443 and fail... no other port.
Can you check that website please and give me any clues? I have already spent more than 2 hours in that :(
Many thanks in advance,
Marcos from Brazil (sorry about any English mistake)
(in reply to cjdjackson)
Post #: 40
