RE: Discussion about SSL Tunnel Port Range Article
All Forums >> [ISA Server 2004 Cache] >> General >> RE: Discussion about SSL Tunnel Port Range Article Page: <<   < prev  1 2 [3]
RE: Discussion about SSL Tunnel Port Range Article - 11.Sep.2009 11:41:14 AM
awojtowicz
what if you dont know the port number the site is using?
(in reply to jnw)
Post #: 41
RE: Discussion about SSL Tunnel Port Range Article - 16.Feb.2010 4:27:42 AM
TreeFox
In order to allow communication you really need to specify the port value.
Jan Hroch
(in reply to awojtowicz)
Post #: 42
RE: Discussion about SSL Tunnel Port Range Article - 9.Nov.2010 4:51:27 AM
habibalby
hello,
I'm having the this issue which I cannot browse SSL sites with non-standard SSL ports. I have created all the recommendation by still i cannot access.
Sites are:
http://electives.med.cornell.edu this redirects to the below site, also I cannot access it.
https://s018.med.cornell.edu:8443/electives
Any help?
(in reply to TreeFox)
Post #: 43
RE: Discussion about SSL Tunnel Port Range Article - 17.Feb.2011 10:50:39 AM
dajohn
Hello Dr. Shinder,
Thank you for your article. It helps a lot since I have no experience with ISA what so ever. I do have some follow up questions for you.
Q1: Will the scripts and GUI you mentioned in the article work for ISA 2006?
Q2: If we have 2 ISA servers in an NLB configuration do we have to do this scripting/GUI on both computers?
Q3: How can we tell if the server has unbound the Web Proxy filter from the HTTP protocol.
Thanks again for your time and advice.
Sincerely,
Daniel
Post #: 44
RE: Discussion about SSL Tunnel Port Range Article - 11.Aug.2011 6:57:04 AM
richardfor
Hi I am running Forefront Threat Management Gateway Version 7.0.9027.400
On a Windows Server 2008 R2 Standard edition
I have tried to run the isa_tpr.js script to first show what ports are currently used, and then the idea was to use it to add additional SSL ports.
However when I run it, it says that usage incorrect this is not an ISA server.
What am I doing wrong?
Richard
Post #: 45
