RE: Understanding the Web Proxy and Firewall Client Automatic Configuration
RE: Understanding the Web Proxy and Firewall Client Aut... - 21.Jun.2006 11:27:28 PM
Gabonescu
Hello Stefaan, Indeed a very acurate article about this auto config. I had to use your recommenations for all IE clients but now I'm comming with a problem: -if I set up IE client with an automatic script (http://FQDN80/array.dll?Get.Routing.Script) I can access my intranet webpage (http://intranet.mycorp.com) BUT I can't access any Ip address (http://172.16.1.22) which is a netwotrk printer for example; -if I set up IE client with a manual proxy ( 172.16.1.1 :8080) I can't access anythink inside and the error is Error Code: 502 Proxy Error. The ISA Server denied the specified Uniform Resource Locator (URL). (12202) Thre is any way to add some exceptions to the automatic script config? I really apreciate any input. Thanks, Gabon
RE: Understanding the Web Proxy and Firewall Client Aut... - 12.Jul.2006 2:35:44 PM
hl.hassan
Hello everyone, Recently i am trying to configure the internet explorer to use automatic detect settings so that the users do not need to specify the ISA server name. I got the internet to work through automatic detect settings,but it is very slow for some reason. All users have firewall client can anyone please help me in why the internet is slow? Note: if i manually specify the ISA sever name the internet works quick. Or if anyone has an article on how to configure automatic detect settings that will be helpfull aswel.
RE: Understanding the Web Proxy and Firewall Client Aut... - 12.Jul.2006 9:24:36 PM
Hi hassan, what do you mean with "...but it is very slow for some reason". Please, elaborate on it. Thanks, Stefaan
RE: Understanding the Web Proxy and Firewall Client Aut... - 13.Jul.2006 11:40:37 AM
hl.hassan
what i mean is that i configured the auto detect settings for the IE the users can browse the intra sites and also browse the internet , but when browsing the internet it is very very slow. If i specify the ISA server name manually in the IE the internet will work more quicker. I hope the information i have provided will help you solve my problem.
RE: Understanding the Web Proxy and Firewall Client Aut... - 13.Jul.2006 10:34:10 PM
Hi hassan, some things to check out: - make sure that Use HTTP 1.1 and Use HTTP 1.1 through proxy connections is enable in the IE advanced settings.
- make sure you have a rock solid DNS name resolving infrastructure.
HTH, Stefaan
RE: Understanding the Web Proxy and Firewall Client Aut... - 11.Aug.2006 4:57:49 PM
thejun
I had an issue come up recently. An OC192 went down, and all my AD DNS servers could not resolve. So i changed my isa to a backup internet connection. I changed the primary dns on ISA to an external DNS address. now, for the clients the browsers are set to autodetect, which pulls the wpad. They all cannot connect. If i change them to manual and type in the proxy server, they can connect fine. I know this is DNS related, but I cannot find a way to fix it so autodetect will work properly.
RE: Understanding the Web Proxy and Firewall Client Aut... - 11.Aug.2006 8:42:07 PM
Hi thejun, what do you mean exactly with quote:
I changed the primary dns on ISA to an external DNS address. Why didn't you just change your forwarders on the AD DNS servers to the new ISP? HTH, Stefaan
RE: Understanding the Web Proxy and Firewall Client Aut... - 18.Jun.2007 3:01:50 AM
btg
hello, Great article, thanks heaps for the information posted. I'm not sure if this problem is related but it is definitely one I have been seeing since activating this feature. Auto configurations is working ok and users are finding the ISA server. I am currently using DHCP + DNS method with the wpad cname. I have found on my isa logs that many browsers are accessing the isa proxy as anonymous. I have intergrated authentication enabled on browsers. I am using IE 6 and IE 7 and trying win2k and winxp sp2 clients. Sometimes logs will show usernames and sometimes it will show anonymous. I tried enforcing all connections to authenticate though this created issues where by many browsers started showing up an authentication box. It was resulting in unhappy users. So I have removed it for now. Do I need to edit the wpad.dat file to enforce this authentication? help would be appreciated.
RE: Understanding the Web Proxy and Firewall Client Aut... - 18.Jun.2007 2:51:27 PM
Hi btg, when you enforce authentication on the web proxy listener, you might run in some authentication prompt issues. You can solve that with KB 885683. For more info, check out: - Getting Prompted for Authentication When You Enable Firewall Client and Web Proxy Client Autodiscovery? - Irritated by Firewall Clients Constantly Being Asked for Credentials? Now, it's normal to see some anonymous requests in the ISA log. When a browser (i.e. IE) sends a request, the browser can't know if authentication will be required. Therefore the initial request is always sent anonymous. When ISA determines that the access rule requires authentication, ISA will reject this request and inform the browser with a 407 response that Proxy authentication is required. The browser will than resend the request with authentication. HTH, Stefaan
RE: Understanding the Web Proxy and Firewall Client Aut... - 28.Jun.2007 9:44:16 AM
Byron Trent
Hi there, This could be just what I am looking for but the link seems to be down. Will it be coming back? Cheers, Byron.
RE: Understanding the Web Proxy and Firewall Client Aut... - 27.Jul.2007 1:22:21 PM
ITGuy85
Reading through the great article, I didn't see the logic behind how the client or ISA determines which is the best ISA to point the proxy to. I understand the wpad process. Here's the scenario. Let's say I have two datacenters (LA and NYC) with internet access and ISA servers at each. Both have two branch offices in hub/spoke fashion. If I take a laptop from branch office A (homed off NYC) to branch office C (homed off LA), what logic does wpad/ISA/IE use to determine which ISA server it should point to? Is it intelligent enough to point to LA or NYC "correctly", and if so, what information does it use? AD sites and services, subnet, pings, hops, etc.? Assuming ISA 2006, IE 7, and XP SP2, and ISA client is installed.
RE: Understanding the Web Proxy and Firewall Client Aut... - 27.Jul.2007 3:11:01 PM
Hi ITGuy85, the only logic used is what DNS or DHCP returns for the wpad request from the client. For DHCP you can define per scope the wpad option. So, this can easily be made location depended. However, for DNS it isn't that simple or even sometimes impossible because you usual don't work with split DNS servers for the internal network itself. You might consider the use of netmask ordering as explained in my blog Multi-Networking WPAD Support in ISA 2004. HTH, Stefaan
RE: Understanding the Web Proxy and Firewall Client Aut... - 27.Jul.2007 3:45:10 PM
ITGuy85
Thanks for the feedback. So the intelligence is very minimal, I take it. Assuming we rely on DNS for staticly assigned servers, I can't quite wrap my brain around an enterprise configuration. If we have 100 subnets of various lengths (/10, /14, /16, /20, /24) across multiple sites, I don't see how the multi-networking solution would work. There aren't ISA servers on each of the subnets, so I can't return an IP address for an ISA server that's on each local subnet. Since static machines won't be leaving the office or moved around, maybe this just calls for a GPO configuration. Roaming clients will be required to use DHCP, and then use intelligent WPAD configuration to point to the desired ISA server. Or am I missing something?
RE: Understanding the Web Proxy and Firewall Client Aut... - 27.Jul.2007 4:13:33 PM
Hi ITGuy85, in my opinion DNS netmask ordening will only work if you can summarize all branches from a datacenter to a 'supernet' of the ISA's internal interface in that datacenter. Moreover, the 'supernet' for each datacenter must have the same subnet length. If that isn't the case, forget DNS wpad for the roaming clients. For the 'static' machines, why not use DHCP reservations and make them DHCP clients too? HTH, Stefaan
RE: Understanding the Web Proxy and Firewall Client Aut... - 27.Jul.2007 4:16:15 PM
ITGuy85
Using reservations is certainly an option. You have given me some great insight and I now have a plan! Thanks!
RE: Web Proxy settings - 2.Jan.2008 4:21:08 AM
abdulaziz
hello experts, I have notice very weird stuff in my client machines, previous we were browsing using proxy setting under port 8080. All clients machine are behind ISA Server, recently I have noticed everyone is browsing with and without Proxy. To my understanding every user who need Internet connectivity should have Proxy Enabled or using secured NAT. But I have choosen Proxy as our settings and it was working fine. But now every machine is BROWSING with and without Proxy.. Please assist me on how to revert back to proxy solution only. Thanks, Abdulaziz
