ISA 2004 Exam - Info Needed!
All Forums >> [ISA Server 2004 Misc.] >> ISA Server 2004 Certification >> ISA 2004 Exam - Info Needed! Page: [1]
ISA 2004 Exam - Info Needed! - 23.Sep.2005 5:25:00 PM
ssrirammca
I'm a naive user getting in touch with ISA(both 2000 and 2004).Could you pls tell me if that would be a good idea to practice ISA with virtual softwares such as Virtual PC or VMWare, sice i don't have access to the same in the realworld network.
Also, is getting certified in ISA 2004 and getting trained on the same would be more beneficial than ISA 2000?
Pls advice.
RE: ISA 2004 Exam - Info Needed! - 25.Sep.2005 9:38:00 PM
Hi RAM,
Yes, ISA 2004 is much better to learn right now. ISA 2000 is getting near end of life. You can learn a lot using VMware to deploy ISA firewall networks. I use VMware all the time and create some pretty fancy networks.
(in reply to ssrirammca)
RE: ISA 2004 Exam - Info Needed! - 26.Sep.2005 8:12:00 AM
ssrirammca
Thanks a Bunch, Tom.
Would that be possible to try out VPN related setups and configurations , while installing ISA 2004 in VMWare or Virtual PC?
Thanks & Regards,
Ram.
RE: ISA 2004 Exam - Info Needed! - 26.Sep.2005 4:53:00 PM
bbroadfoot
Ramvas,
Hopefully you have grabbed a copy of the Configuring ISA 2004 book by Tom.
In there he does have a configuration for a lab (Chapter 4 - ISA 2004 Network Concepts and Preparing the Network Infrastructure) and what you need. Hopefully you have a machine with a bunch of RAM and you can go about running up this configuration (I think it is just shy of 1GB for the virtual machines + your underlying OS and Virtualisation software to consider).
If you are really serious about getting your qualifications for this then the best way to learn is in the deep end with the product, the book and a browser open at isaserver.org!
And when you are finished, you have a machine that you can build other labs in for other products to further your education.
Good luck!
RE: ISA 2004 Exam - Info Needed! - 27.Sep.2005 3:44:00 AM
ssrirammca
Thanks a bunch for the valuable suggestions, BartB.
I'd grab the "Configuring ISA 2004" book today, and would start working on it, for my learning and certification.
Thanks once again.
Ram.
RE: ISA 2004 Exam - Info Needed! - 27.Sep.2005 5:14:00 PM
bbroadfoot
No probs - glad to be of assistance.
