RE: Emule Configuration ISA 2004
All Forums >> [ISA Server 2004 Misc.] >> Gaming >> RE: Emule Configuration ISA 2004 Page: <<   < prev  1 [2]
RE: Emule Configuration ISA 2004 - 18.Aug.2005 5:46:00 AM
JesseA
John,
In ISA management console:
Configuration->General->Define Firewall Client Settings->Application Settings
(in reply to Hegris)
Post #: 21
RE: Emule Configuration ISA 2004 - 20.Aug.2005 6:28:00 AM
amahook
thanks alot for the informations about emule,
can any one send the file to my email because the http://www.2and2.net/Priv/EmuleIsa2004STDConfig.doc
is block from our ISP.... i don't know why??
my email is amirmahook@hotmail.com
thanks again
Post #: 22
RE: Emule Configuration ISA 2004 - 4.Nov.2005 10:57:00 AM
SweMuc
thanks Hegris for your awsome guide, now i finally get "high id" in emule and overnet also works grat.
Post #: 23
RE: Emule Configuration ISA 2004 - 18.Jan.2006 9:19:34 PM
astimas
Hi, I follow the tutorial (great tutorial) by Hegris  but  I still have low-id on emule
I use emule directly on windows server  and not on a client . Can is this the problem ?!?
(in reply to SweMuc)
Post #: 24
RE: Emule Configuration ISA 2004 - 18.Jan.2006 9:50:57 PM
astimas
ORIGINAL: Guest
Hi people,
I installed ISA 2004 on windows 2003 server, I have emule on a client connected by LAN, I followed the guide of Hegris, but my emule still have the low id, so I tryed the tips of Bruno, about to add a server publish rule and now I have High id !Now I still have to configure the Kad server, anyone know how to add it to isa?
Ciao,
Marcello
Sorry but what you means when you said "add a server publish rule" ? I don't understand ?!?
(in reply to Guest)
Post #: 25
RE: Emule Configuration ISA 2004 - 25.Mar.2006 9:46:17 PM
moTaro
Here is what I have managed to do to Get Connection to Mule and Kad Network with HighID.
The scenario is: I have Windows 2003 Server with ISA 2004 installed and I want to use Emule on the same machine (Local Host).
This rule only works with DonkeyServerNo1 (or any other server that uses port 4242)
Task 1:
Create New Protocol:
Name: Emule Open Ports
Parametars:    TCP 4242 Outbound
                 TCP 4662 Outbound
                 UDP 4672 Send
Task 2:
Create Access Rule:
Action: Allow
Protocol: Emule Open Ports
To: External, Local Host
There you go. Enjoy your High ID on the Local host!
< Message edited by moTaro -- 26.Mar.2006 7:11:41 PM >
God is a Machine
Powered by BSD
(in reply to astimas)
Post #: 26
Emule Configuration ISA 2004 - more ports - 1.May2006 12:12:54 AM
Heisenberg
first: big THX to moTaro
it works this way.
i just wann'append some ports to make your emule more flexible
moTaro wrote:
Task 1:
                TCP 4662 Outbound
                UDP 4672 Send
Task 2:
Create Access Rule:
Action: Allow
i suggest to add some more ports like:
Parameters:
                TCP 3000 Outbound
                TCP 3006 Outbound
                TCP 4242 Outbound
and any other ports you see in the server list of your emule client
                TCP 4661 to 4665 Outbound
                UDP 4672 Send
but again: brilliant thread by moTaro
Heisenberg
Never Stop !
(in reply to moTaro)
Post #: 27
How to block Emule on ISA 2004 - 3.Jul.2006 8:32:21 AM
mabolhasani
I need to restrict my internal users to use P2P file sharing programs specifically Emule. I have configured some HTTP Signatures and Headers. Fortunately Kad is not now accessible but eD2k can be used. Do you have any solution to block it forever?
Yours,
Mohammad
(in reply to JesseA)
Post #: 28
