Discussion about part 1 of the SBS install series
RE: Discussion about part 1 of the SBS install series - 24.Aug.2005 12:25:00 PM
ababinchak
Tom,
There are some really dramatic differences in the way that the upgrade from ISA2000 is configured vs. a clean install is ISA2004 using the SP1 CD set. An article on these would be in order. I've been making a collection of them and could contribute.
Nice to see SBS finally getting its due.
Amy
RE: Discussion about part 1 of the SBS install series - 24.Aug.2005 12:52:00 PM
Compukirk
Tom-thanks for this series of articles. One comment is that typically a new install of SBS 2003 would have an internal NIC IP of 192.168.16.2 instead of the 192.168.2.0 you have listed. I just did my first SP1 install with slipstreamed media and it also defaults to that IP. Of course that can be changed during the setup with the wizards and there is another wizard you can run anytime later that will also easily change the internal IP.
RE: Discussion about part 1 of the SBS install series - 24.Aug.2005 6:56:00 PM
Amy
Hi Amy,
Do you think it would be worthwhile to show how to do it with a clean ISA2k install? The reason I ask is because the upgrade conversations are pretty whacky. But now that I say that, it would be an interesting exercise.
OK! You got it! Once I finish the clean install article, let's work together on a upgrade install article series.
Thanks! Tom
RE: Discussion about part 1 of the SBS install series - 24.Aug.2005 6:58:00 PM
quote: Originally posted by Compukirk: Tom-thanks for this series of articles. One comment is that typically a new install of SBS 2003 would have an internal NIC IP of 192.168.16.2 instead of the 192.168.2.0 you have listed. I just did my first SP1 install with slipstreamed media and it also defaults to that IP. Of course that can be changed during the setup with the wizards and there is another wizard you can run anytime later that will also easily change the internal IP.
Hi Kirk,
Arrg! You're absolutely right! I had "2" stuck in my head and had worked on another scenario earlier in the day using a 192.168.2.0/24 netowrk ID.
I'll fix that right now.
Thanks! Tom
RE: Discussion about part 1 of the SBS install series - 24.Aug.2005 7:05:00 PM
DAW
Great intro, I hope that you will address hosting Internet websites (multiple in my case) on the SBS/ISA box. The web publishing rules in combination with split DNS and SSL was very confusing to me, and I still have at least one bug in my config (fortunately it errors on the side of denying service).
Also I would love to hear your take on the default set of firewall and policy rules the wizards setup. Some seem unnecessary and potentially hazardous (DHCP on WAN interface, ICMP, and DNS rules for example).
I was restrained by budget to put everything in one basket, but because we have a few notebooks on the network, I LOVE that my server is setup not to trust LAN connections as well as WAN.
Thank you again for taking up the flag for us lowly SBS'rs :-)
-Dave
RE: Discussion about part 1 of the SBS install series - 24.Aug.2005 10:03:00 PM
quote: Originally posted by DAW: Great intro, I hope that you will address hosting Internet websites (multiple in my case) on the SBS/ISA box. The web publishing rules in combination with split DNS and SSL was very confusing to me, and I still have at least one bug in my config (fortunately it errors on the side of denying service).
-Dave
Hi Dave,
Great ideas! Articles I can generate from these are:
1. Publishing Multiple Public Web sites on the SBS computer using a split DNS infrastructure
2. Another redenition of the Split DNS infrastructure article -- but this time with well defined step by steps that you can replicate
3. Discussion of the default SBS System Policy
4. Discussion of the SBS firewall policy created when you allow all SBS services to be accessed remotely
There in the queue! Thanks! Tom
RE: Discussion about part 1 of the SBS install series - 25.Aug.2005 12:19:00 PM
dvord
Tom,
Honestly I'm very surprised and a bit disappointed that isaserver.org is going to be supportive of SBS.
MVP's have come right out and said that SBS's implementation, forcing administrators to run the Domain Controller on the same machine as the ISA Server is nothing less than watching a car crash in slow motion.
Most security folks understand that the most secure environment has key systems like firewalls and proxy servers located away from business-critical functions like collaboration applications (Exchange), and business organization functions (like AD, File and Print, etc.). By design, SBS flies in the face of conventional security. What makes matters worse is that Microsoft is frequently the target of attacks by hackers. Turning a bad situation ugly by putting vulnerable systems all together in one package.
I have posted several questions regarding SBS on Microsoft's own news server on support of this product and I'm frequently told by MVP's that "oh you shouldn't run a public website on SBS", or stating that other features which Microsoft MARKETS with SBS aren't to be used because they are flawed or highly problematic. This is not indicative of a healthy, secure system.
Security advocates have a responsibility to the people who listen to them, and ultimately to the greater good at large.
Is SBS now secure enough that concerns about ISA being on the DC are no longer valid? Wouldn't you agree that if Microsoft is marketing a critically flawed product, it is a disservice to the administrative community (and IT consumers at large) to give it "time" from such a well-recognized authority such as yourself?
RE: Discussion about part 1 of the SBS install series - 29.Aug.2005 5:39:00 AM
nigejn
I've had a look through the article and Scenario 3 is an interesting one. I can see the cost implications involved in buying an additional ISA Server, but if a HP DL320 ISA server for ú1700 ($3000) is purchased, it doesn't cost much more than a non ISA firewall, like Juniper or Watchguard.
I've been looking at a new firewall solution for our business and i've been considering an ISA Server.
Tom does your new book cover configuring 2 ISA server like in Scenario 3?
Nigel
RE: Discussion about part 1 of the SBS install series - 29.Aug.2005 10:44:00 AM
Hi D,
Its true that SBS represents a security compromise. But given the large and increasing installed base, it seems to me that the best approach is help those folks secure their installations as much as possible.
Many of us have encouraged MS to unbundle an ISA and Windows lic for a single white box install of ISA, but those requests fall on deaf ears
Thanks! Tom
RE: Discussion about part 1 of the SBS install series - 29.Aug.2005 10:47:00 AM
quote: Originally posted by nigejn: I've had a look through the article and Scenario 3 is an interesting one. I can see the cost implications involved in buying an additional ISA Server, but if a HP DL320 ISA server for ú1700 ($3000) is purchased, it doesn't cost much more than a non ISA firewall, like Juniper or Watchguard.
Nigel
Hi Nigel,
Yes, there is some coverage of the back to back config, but not SBS specific. I have completed a series of articles on back to back configs, and one of them includes a SBS-like scenario. I'll be doing one soon that does incorporate SBS to show you exactly how to do it.
HTH, Tom
RE: Discussion about part 1 of the SBS install series - 29.Aug.2005 10:51:00 PM
AHIT
I'm glad to see you've "come around" with respect to the use of SBS and the value proposition of "doing it all" with your available hardware. The fact of the matter is, SBS exists and has a pretty big following. Here in Australia at the moment there's a pretty big push from Microsoft on teh SBS product. Not every organisation can afford the hardware to have a DC server, a global caatlog server, a DHCP server, a file&print server, a seperate firewall server/device etc etc.
For some time I've pushed the benefits of "dumb hardware firewalls" to my customers and online @ How to ensure your network security using Microsoft ISA Server. This helps in getting the most bang for your buck from your hardware by reducing the amount and type of raw traffic your ISA has to deal with.
I've been most heartened over the last 12 months or so to see how you & isaserver.org has tried to debunk some of the myths about "how much better hardware firewalls are". One only needs to do a quick Google search or somewhere like Cert.org search on firewall vulnerability to see that these "hardware" firewalls MUST run some sort of software and aren't necessarilly inherrently any more secure. Cisco, Checkpoint, Gauntlet I think you'll find them all there somewhere.
Kudo's on a well written article on a subject matter that was previously glossed over.
RE: Discussion about part 1 of the SBS install series - 30.Aug.2005 9:22:00 AM
ababinchak
Na, I don't think that there is any advantage to explaining the clean install of ISA2000 no one will be doing that anymore. When you run the upgrade from a clean ISA2000 install to ISA2004 you'll be really surprised to see what happens. I'm no longer running the upgrade. I uninstall ISA2000 and then install ISA2004. Otherwise you end up with an ISA2004 server acting like an ISA2000 box and it messes with my mind when I try to configure it for the company that owns it.
We are using 'el cheapo pinhole firewalls to take the pressure off. The major benefit is that it gets rid of most of the port scans that dynamic IP networks are prone to. Side benefit when even though the business is under contract to me, the family genius comes home from college where "he's studying engineering but he knows a lot about computers too" decides to make a few changes so things can run faster, the pinhole firewall holds down the fort until I get there to straighten things back up.
It's an interesting world.
RE: Discussion about part 1 of the SBS install series - 2.Sep.2005 3:18:00 AM
humorfox
This is a great article. Thank you so much for this sharing.
In addition, it seems there is a mis-typed information:
"The internal interface can use any private (non-Internet routable) address you like. The key requirement is that the IP address on the internal interface of the simple stateful packet inspection firewall or NAT device in front of the SBS 2003 SP1/ISA firewall must be on the same network ID as the external interface of the SBS 2003 SP1/ISA firewall computer. For example, you could assign the IP address 192.168.1.1/24 to the internal interface of the NAT device and assign the IP address 192.168.16.0/24 to the external interface of the SBS 2003 SP1/ISA firewall."
If my understanding is correct, the last sentence should be "For example, you could assign the IP address 192.168.1.1/24 to the internal interface of the NAT device and assign the IP address 192.168.1.0 /24 to the external interface of the SBS 2003 SP1/ISA firewall". After that, the external NIC of the SBS and the internal NIC of the BE firewall will be in the same subnet. [ September 02, 2005, 03:22 AM: Message edited by: Cameron Ye ]
RE: Discussion about part 1 of the SBS install series - 6.Sep.2005 7:06:00 PM
Tyler
New question (RE: Scenario 3):
Here's my existing network config:
SBS 2k > ISA 2k (separate Win2k Server box)
ISA 2k has 2 NICs, one to cable modem, one to LAN.
I'm getting ready to replace the SBS 2k with an entirely new box, so the config will be:
SBS 2k3 Premium > ISA 2k (no change from above).
Here's the question/situation: I would like to implement Scenario 3 since I have all of the building blocks, but is there an issue with the SBS 2k3 running ISA 2004 on the inside and having ISA 2k on the outside?
RE: Discussion about part 1 of the SBS install series - 7.Sep.2005 10:52:00 AM
quote: Originally posted by Cameron Ye: This is a great article. Thank you so much for this sharing.
Hi Cameron,
Ouch! Thanks for the update. I'll correct that now.
Thanks! Tom
RE: Discussion about part 1 of the SBS install series - 7.Sep.2005 7:06:00 PM
kevfitz
In part 1 of the ISA with SBS 2003 SP1 I get the conclusion that you should have an ISA Server in front of your Small Business Server so just ISA is "internet facing" to provide the application layer filtering for modern attacks.
You mention the security zone where Small Bis Server with ISA being different from the zone where secure assets are located.
I have a diagram that shows the internet, the router, the FW and the switches in one zone and the ISA Server, Exchange Server and SQL etc.. in the the second zone behind the switch.
According to you the ISA Server should be out in the zone 1 as the router and internet facing firewall?
