Discussion of Configuring Outlook 2003 RPC over HTTP client article
Discussion of Configuring Outlook 2003 RPC over HTTP cl... - 5.Jan.2004 1:59:00 PM
This thread is for discussing the article on configuring the Outlook 2003 client to use RPC over HTTP at http://www.msexchange.org/tutorials/outlookrpchttp.html.
Thanks! Tom [ January 05, 2004, 02:29 PM: Message edited by: tshinder ]
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 8.Jan.2004 8:32:00 PM
You can indeed create a profile while not on the network hosting the Exchange 2003 server... In my experience, all Outlook will do is complain that it cannot verify the login and you can just continue on and configure for RPC-HTTPS... Once you start Outlook, it will connect via RPC-HTTPS as usual...
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 9.Jan.2004 2:55:00 AM
Hi Ryan,
Thanks! I've never been able to make it work that way. Maybe I wasn't trying hard enough? It seemed that the profile creation process just halted when the client wasn't able to connect and confirm the account. I'll have to try things again and see what happens.
Thanks! Tom
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 10.Jan.2004 1:21:00 AM
Yes sir, After configuring Windows Server 2003 and Exchange 2003 to accept RPC/HTTPS, as well as configuring the PIX to only allow ports 80, 143 and 443 through to Exchange 2003. I was able to sucessfully configure my Outlook 2003 client at my home office to connect to Exchange via RPC/HTTPS throught the PIX.
Outlook 2003 complains about not being able to verify the account because 135 is not availible, but after finishing up the configureation, the connection is able to be made.
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 11.Jan.2004 6:25:00 PM
Hi Ryan,
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 14.Jan.2004 11:14:00 AM
Pela
First, to figure 6 it's a backend exchange server you need to type in here.
In the final version of Outlook 2003 there seems to be some problems with UPN logon, the KB830355 solved my first logon with RPC over HTTPs problems. http://support.microsoft.com/?id=830355
/Peter
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 15.Jan.2004 2:31:00 PM
Pela
Port 143/tcp is IMAP and isn't needed for RPC over HTTPs. Is the CA for the certificate imported in "Trusted Root CA"? Have you tried <servername>.<ad domaine> in The "Microsoft Exchange Server? In Exchange Proxy settings the server name need to be the domain name the certificat is issued to.
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 15.Jan.2004 2:33:00 PM
quote: Originally posted by Peter Larsen: First, to figure 6 it's a backend exchange server you need to type in here.
/Peter
Hi Peter,
But if you enter the back end Exchange Server, that would not resolve correctly, since the publishing rule redirects requests to the front end server.
Thanks! Tom
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 15.Jan.2004 4:02:00 PM
Pela
But you'v already made a tunnel throug the frontend server. This is the only way i'v got it to work behind a router with only port 80 and 443 open. Then again i haven't tried without the patch for UPN logon...
/Peter
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 15.Jan.2004 6:52:00 PM
ryguy
Certificate has been imported and is trusted.
I can connect to exchange perfectly using the local dns name (ie servername or servername.domain) Any other suggestions?
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 16.Jan.2004 1:07:00 AM
Hi Ryguy,
If you're trying to remotely access it, make sure your DNS is configured according the suggestions in the ISA/Exchange Kit.
However, only the front end server is published in the doc in the kit. The situation may be quite different with RPC over HTTP publishing when there is only a single Exchange Server and no front end.
HTH, Tom
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 16.Jan.2004 12:23:00 PM
Pela
That's is also the only way i made it work, i wasn't able to use a fqdn like webmail.domaine.com only servername.ad_domainename.
/Peter
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 16.Jan.2004 3:20:00 PM
Pela
Hi Tom
Sure, if you can connect with RPC while configuring the profile the client resolves the correct servername and configures it in the profile. But if you only have HTTPs access you have to be very specific with the FQDN for the exchange server.
/Peter
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 18.Jan.2004 11:57:00 AM
Hi Peter,
Exactly. The SSL connections require that the FQDN are the same as those on the certificates.
Thanks! Tom
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 26.Jan.2004 7:59:00 AM
eegon
Hi Everyone. I have port 135 blocked by my ISP. I have NEVER had the computer I'm setting up the Outlook profile, on the internal network. I have tried everything I can think of, and cannot get a connection using ONLY Rpc over HTTP. It does however work great from another external site that DOES have 135 open and able to resolve the internal server name. Anyway, I'm ready to try the ORK solution, but I don't understand how others have gotten this to work, and why Microsoft would design it not to connect if the machine never sees port 135. ANY help is most appreciated. It seems there must be something I'm missing as I am for certain that if 135 goes through, I can connect, using the same settings on another computer just on a different cable modem with a different ISP. I am also FOR CERTAIN that when it connects it is using HTTPS - so I know the servers are correct.
Thanks for any thoughts anyone has on the subject.
RE: Discussion of Configuring Outlook 2003 RPC over HTT... - 26.Jan.2004 2:04:00 PM
Hi Eegon,
I'm told that if you don't click the "Check Name" button, you will be able to create the profile without RPC connectivity.
Check it out and let me know if it works for you.
Thanks! Tom
