Discussion of using a Wildcard Certificate in ISA2004 article
Discussion of using a Wildcard Certificate in ISA2004 a... - 1.Feb.2004 8:34:00 PM
This thread is for discussing the Using a wildcard certificate in ISA2004 article at http://isaserver.org/tutorials/2004wildcardcert.html.
Thanks! Tom [ February 01, 2004, 08:43 PM: Message edited by: tshinder ]
RE: Discussion of using a Wildcard Certificate in ISA20... - 1.Feb.2004 10:49:00 PM
jide
Good and informative information as always. But can you do the same thing on ISA 2000 or is this only possible with ISA2004.
Thanks.
Jide
RE: Discussion of using a Wildcard Certificate in ISA20... - 1.Feb.2004 10:54:00 PM
Hi Jide,
Works great in ISA2000 too.
HTH, Tom
RE: Discussion of using a Wildcard Certificate in ISA20... - 2.Feb.2004 3:59:00 AM
willabr
Publishing Multiple Web Sites:
When I get to adding the second site (www) I do not have the "Create a new certificate" selection. I would have to remove the current certifacte (owa) before I can create a new one. Is this correct or have I done something out of order.
Thansk
RE: Discussion of using a Wildcard Certificate in ISA20... - 2.Feb.2004 5:04:00 AM
Hi Bruce,
The second site, which listens for "www.domain.com", is on a *different* Web server, not the same one as the OWA site. Check out the sample lab config to see that there are two Web servers in use. You can accomplish a similar thing with one Web server if you've created two virtual Web servers.
HTH, Tom
RE: Discussion of using a Wildcard Certificate in ISA20... - 2.Feb.2004 3:40:00 PM
andifur
This is great, but for audit reaons,we are not allowed to publish SSL sites with home grown certs. Do you know if Verisgn or Thawte allow the creation of wildcard certs? [ February 02, 2004, 03:40 PM: Message edited by: andifur ]
RE: Discussion of using a Wildcard Certificate in ISA20... - 2.Feb.2004 3:44:00 PM
Hi Anthony,
Possibly. I know of less well-known public cert providers that do this, but the big boys probably would require an arm and a leg, since you pay per cert.
RE: Discussion of using a Wildcard Certificate in ISA20... - 2.Feb.2004 9:54:00 PM
Linke Loe
Hi Tom. I gues this would also work when you only have to publish the OWA-site?
For me it didn't. I followed all steps in your article except those for the second website. When I try to access my OWA-site I get the error mesage: 403 - Forbidden. The server denies the specified URL.
Thanks for the article though. Great work.
RE: Discussion of using a Wildcard Certificate in ISA20... - 2.Feb.2004 11:30:00 PM
Linke Loe
I've taken a closer look at what happens. I've monitored and logged my requests for my OWA-site and saw that every request I made was denied by the default firewall rule, wich denies all traffic. This means that the firewall policy skips the firewall rule created by the web publishing wizard.
When I took a closer look at the firewall rule for the OWA publishing, I saw that the protocols allowed are HTTP and HTTPS, not 'HTTPS Server'. Could this be the problem?
RE: Discussion of using a Wildcard Certificate in ISA20... - 4.Feb.2004 3:56:00 PM
Linke Loe
I've run the article over again and suddenly, the publishing worked...
RE: Discussion of using a Wildcard Certificate in ISA20... - 25.Feb.2004 7:28:00 PM
i-have
I have the following question about publishing the owa site on a different name than the internal domain name. I followed the totural with the different name than the domain. From the internet everyting is working oke. But from the inside (firewall clients) I get an error:
<TD width= The page cannot be displayed
I added the different name to my dns server as a lookup zone and added the exchange server to it. Now it only works when I turn of the firewall client.
Is there another way of doing this?
Already thanks!
i-have
RE: Discussion of using a Wildcard Certificate in ISA20... - 28.Feb.2004 3:20:00 AM
gatorz
When i go to select the cert in the new Web listener, it tells me there are no certificates configured on this server i have verified that the certificate is installed per the article
any ideas
gatorz
any ideas
RE: Discussion of using a Wildcard Certificate in ISA20... - 19.Apr.2004 5:51:00 PM
JamesD
Just a warning regarding Wildcard certificates... the successful validation (client-side) of SSL certificates is application dependant.
For example, using your PocketPC to browse a web site protected by a wildcard SSL certificate works fine..... however, if you publish Server ActiveSync using a wildcard SSL certificate, the client-side ActiveSync application will refuse to validate the server's certificate (unless certificate validation is disabled).
This has been confirmed as expected behaviour by Microsoft PSS.
So just beware, and double-check any non-browser apps before you shell out!
Cheers, James.
RE: Discussion of using a Wildcard Certificate in ISA20... - 19.Apr.2004 7:33:00 PM
paulbaldwin
Hi James,
You've got me there.
I've been using a wildcard certificate for OWA, OMA, RPC over HTTP, Sharepoint and Exchange ActiveSync! I used both SmartPhones and iPaqs running PocketPC 2002 (and 2003 I think).
What have Microsoft PSS been telling you?
RE: Discussion of using a Wildcard Certificate in ISA20... - 19.Apr.2004 8:25:00 PM
Hey guys,
Paul is THE MAN when it comes to ISA and Smart Phone deployment. When he says it works, it DOES.
HTH< Tom
RE: Discussion of using a Wildcard Certificate in ISA20... - 23.Apr.2004 2:03:00 AM
I have having the same problem as gatorz posted. Any ideas?
>gatorz >posted February 28, 2004 03:20 AM >-------------------------------- > When i go to select the cert in the new Web listener, it tells me there are no certificates configured on this server i have verified that the certificate is installed per the article
>any ideas
