Unable to access TSClient
All Forums >> [ISA Server 2000 General] >> Server Publishing >> Unable to access TSClient Page: [1]
Unable to access TSClient - 3.Jul.2001 4:22:00 PM
sysreq
I have followed the TSAC tutorial to the letter, well apart from having things configured slightly differently inside my network.
The problem I have is that the server publishing rule does not publish. If i set it to publish smtp and to a netstat -an I see the port listening.
However if set it of terminal server (incoming on 3389). It doesn't listen.
I have terminal services running on the system and can see 0.0.0.0:3389 listening.
Is this the problem?
Any suggestions?
RE: Unable to access TSClient - 3.Jul.2001 5:02:00 PM
sysreq
Ok I have found a post elsewhere that says you shouldn't have Terminal Services running on the ISA box and if you no use different ports.
How, Why?
(in reply to sysreq)
RE: Unable to access TSClient - 7.Jul.2001 7:24:00 AM
Hi sysreq,
You have to change the listening port on the ISA Server if you want to publish Terminal Services on the internal network. Check the 'bugs' section on this site for a Q article on how to do this.
Tom Shinder
Get It Here
