RE: error in publishing a mail server
All Forums >> [ISA Server 2000 General] >> Server Publishing >> RE: error in publishing a mail server Page: <<   < prev  1 [2]
RE: error in publishing a mail server - 25.Jul.2005 4:09:00 PM
Hi nnmmss,
I would first test the following scenario:
1. make sure that the web mail server asks only for Basic authentication or uses a form.
2. make sure that *no* authentication is requested at the incoming web request listener of ISA server.
(in reply to nnmmss)
Post #: 21
RE: error in publishing a mail server - 26.Jul.2005 8:34:00 AM
nnmmss
Hi dear stefaan
you helped me alot during this experience. this part was also successful. now i have one question, if set for incoming web request listener of ISA server doesn't need authentication, is it secure? can anonymous users use My ISA server as their proxy server?
Thanks alot
Post #: 22
RE: error in publishing a mail server - 26.Jul.2005 4:38:00 PM
Hi nnmmss,
first of all, if you web publish an internal web server and don't ask for authentication on the ISA level, then any Internet user can access only that published web server. That means they will get the authentication prompt from the Web server.
Nevertheless you can enhance a lot the security. I strongly suggest you upgrade to ISA server 2004 in such a scenario. You can then use:
1. HTTPS bridging or HTTPS to HTTP bridging if the web server don't support HTTPS.
2. pre-authenticate at the ISA level and if succesful then automatically forward the credentials to the Web server so the users need not to authenticate twice.
3. use the HTTP filter to scan the HTTP traffic, even if the outside and inside connection is HTTPS.
4. use an add-on product such as Collective Software FlexAuth from http://www.collectivesoftware.com/ and implement forms based authentication on the outside (just like OWA) to enhance the authentication process.
5. ...
Note: some of the above points can already be implemented with ISA 2000.
Post #: 23
