FW Client Deployment
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> FW Client Deployment Page: [1]
FW Client Deployment - 6.Feb.2002 12:45:00 AM
Muhammadn
When I deploy FW Client via GP:
1. Exchange IM give Proxy sock 5 error.
2. there is no place where I can find the installation.
3. Add remove program indicate FW client is installed.
On Manuall install every thing works fine.
Any Idea what I m doing worng in deploy FW Client via GP (had tried both ways Assign and Publish)
Muhammad Nadeem
RE: FW Client Deployment - 13.Feb.2002 5:40:00 PM
Hi Muhammad,
Do you see the authenticated Firewall client sessions in the log files and the ISA Management console?
(in reply to Muhammadn)
RE: FW Client Deployment - 14.Feb.2002 10:35:00 PM
Muhammadn
I had checked ISA log as well as ISA Management console ..... no indication of any Session !
But in Add/remove program .....it is showing that FW client is installed.
anyother way to deploy FW Client via GP ?
Muhammad Nadeem
RE: FW Client Deployment - 15.Feb.2002 6:37:00 PM
Doc
are you publishing it or assigning it?
sounds like it's published
RE: FW Client Deployment - 15.Feb.2002 9:29:00 PM
Muhammadn
I have tried both ways.....
In case of Publish: nothing Install automatically
In case of Assign: It is showing in Add/Remove programs that "FW Client Installed"....but no icon in Control Pannel and nothing in Programs.
No session in ISA log or ISA Management console.
I have no clue why it is happening...... I m using the same policy and same user to deploy other S/W..working fine.
RE: FW Client Deployment - 15.Feb.2002 10:35:00 PM
Doc
i have mine published and works a well, just logon - add/remove programs - add new software button and it's listed there
i think if you assign it you might want to assign it to the machine and not users
RE: FW Client Deployment - 16.Feb.2002 12:19:00 AM
Muhammadn
With publish and using Add/remove ..it will be working fine........but it require user interaction.
I don't want USER to do anything. Just login and Install automatically.
Tomorrow I will try to use "Assign to computer" and will let u know .
Thanks for all ur help
RE: FW Client Deployment - 19.Feb.2002 8:34:00 PM
Muhammadn
Hi Doc,
Today I tried it by Assigning to Computer.. &...it is working fine.
Thanks for all ur help.
Muhammad Nadeem
