I am asking you a question which is coming in any ppl mind n professional. I personlly running cable.net setup's n cyber cafe's . We cannot do pc to pc voice chat from a client behind ISA. All settings have been checked. Client is running firewall client. I have also created he the key for msmsgs (nameresolutionforlocalhost<P>) , eveythign is fine n running. But msn pc to pc voice is not working. Scenario is I m behind isa server ,firewall client installed, directly connected to iNternet which means no socks or proxy, but whenever I try to call the desired person who is connected directly to the iNternet, I cannot connect, error comes that the call has been ended or I am blocked by the firewall or contact admin. So do anybody have briefly descirbed and proven solution so that many ppl can get benefited from it. Thank You
Syed Jahanzaib Network Administrator AA Cable.Net Service & Millenium Cyber Cafe's
MSN voice/video will not work behind ISA Server because its not UPnP compliant.
However, it will sort of work if the other person is directly connected to the Internet and they call you. You will not be able to call the other person and use voice/video.
ok, If pc to pc voice chat is not supported through ISA, is it possible to make a voice or vido call through netmeeting. I am conencted behind isa server using gatekeeper, n the other person is connected directly to the internet. Will I be able to have voice chat? When will ISA be support uPNP? n wht is uPNP by the way?
