PDC Behind ISA Need to Access Email Server OutSide
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> PDC Behind ISA Need to Access Email Server OutSide Page: [1]
PDC Behind ISA Need to Access Email Server OutSide - 11.Apr.2002 7:35:00 AM
PingMonster
I have PDC behind ISA and this PDC need to send and receive email through outside email server (UNI Campuse).
Installing Firewall client on PDC seem to fix this problem but it is dog slow to boot up.
PDC is pointing to ISA as gateway (SecureNet)
and I don't have internal DNS server so PDC does not point to any DNS.
I found in ISA session that PDC SYSTEM is connecting as Firewall session.
What da hell am I doing wrong?
"[Mad]"
RE: PDC Behind ISA Need to Access Email Server OutSide - 13.Apr.2002 4:56:00 PM
Hi PingMonster,
no internal DNS server?!? [Eek!]
I would *not* install the Firewall client on a PDC. Make sure the PDC is a SecureNAT client and define your ISP DNS server in the interface TCP/IP properties.
Next, create the necessary protocol rules for POP3/SMTP/DNS and make sure you have a proper site&content rule in place. If you want, you can restrict those protocols to a particular client address set who contains your PDC.
(in reply to PingMonster)
RE: PDC Behind ISA Need to Access Email Server OutSide - 16.Apr.2002 3:31:00 AM
PingMonster
Thanks Spouseele
May be I did not explain clearly enough.
We are in University situation. (Virtual Land)
There is a main DNS server within university which is outside of ISA Server.
And our computer LAB is behind ISA.
The bad thing is we are not allowed have our own DNS server.
Is there a downside not having internal DNS, even just as forwarder?
At the moment I just have it as open access and open protocols with default packetfilter and still cannot access the email server in the University without firewall client installed.
Of cause I have it as secureNET client.
RE: PDC Behind ISA Need to Access Email Server OutSide - 16.Apr.2002 11:28:00 PM
Hi PingMonster,
ISA is highly depending on a solid DNS infrastructure. You can perfectly setup an *internal* DNS server and use the main DNS server within the university as forwarder. The internal DNS server will only be authoritative for your lab environment.
If you said it worked with the firewall client, is the University DNS server set at ISA? Probably yes! That could be the reason it works. If the Firewall client has no DNS settings, then ISA will performe the DNS lookup on behalf of the Firewall client. This is not the case for a SecureNAT client! So, a workaround could be to define the University DNS server in the TCP/IP properties of the SecureNAT client.
Check out:
- http://www.isaserver.org/authors/harrison/tutoials/isa-clients-part1.htm
- http://www.isaserver.org/authors/harrison/tutoials/isa-clients-part2.htm
- http://www.isaserver.org/authors/harrison/tutoials/isa-clients-part3.htm
RE: PDC Behind ISA Need to Access Email Server OutSide - 18.Apr.2002 12:49:00 AM
PingMonster
Thanks Stefaan
Like I said "We are not allowed to have DNS server" in our domain.
I think the Firewall client is the only way.
Why is it everyone saying "DONOT INSTALL" Firewall client on PDC or BDC?
RE: PDC Behind ISA Need to Access Email Server OutSide - 18.Apr.2002 6:14:00 PM
Hi Stefaan,
I agree! Never put the Firewall client on a DC [Eek!]
SecureNAT clients should work fine in such an environment. But there no reason why you can't set up your own DNS server in the Lab. Its not like you're setting up a rogue DCHP server or anything like that. [Big Grin]
HTH<
RE: PDC Behind ISA Need to Access Email Server OutSide - 18.Apr.2002 10:37:00 PM
Hi PingMonster,
I can only say: re-read my previous post. Have you already tried the workaround?
RE: PDC Behind ISA Need to Access Email Server OutSide - 19.Apr.2002 2:27:00 AM
PingMonster
Thanks Tom and Stefaan
I know it is sad that we cannot have our own DNS but think of all other faculties having their own DNS and not to mention unauthorised name records and supports. That's why they won't allow us to have one. [Frown]
Yes, Stefaan
I did tried the workaround still does not work with just the SecureNET, WebProxy and UNI DNS.
(Just not enought power captain! She needs firewall client)
RE: PDC Behind ISA Need to Access Email Server OutSide - 19.Apr.2002 5:31:00 PM
Hi PingMonster,
I really don't understand your problem.
If a SecureNAT client is setup correctly, you should *not* have any problems to send and receive email through outside email server.
Check out again http://www.isaserver.org/authors/harrison/tutoials/isa-clients-part2.htm .
