ftp with -a DOS command
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> ftp with -a DOS command Page: [1]
ftp with -a DOS command - 21.Jun.2002 9:27:00 AM
erica_zhu
anyone can tell me if i run my FTP in DOS, i cann't get it work with ftp but it works with ftp -a, i know that i have to delete the external IP address on the ISA server, but i cannot do that, since both NIC IP address are internal. So what other solution that i can use IE browser for FTP??? how to use FTP -a in IE???
RE: ftp with -a DOS command - 21.Jun.2002 11:58:00 AM
erica_zhu
any one can help??
the reason why i can't delete the external IP is, my current IP setting like this
External IP:192.168.0.2
External Gateway: 192.168.0.1(which is symantec firewall, hardware)
Internal IP: 192.168.68.1
Now my case is both IP are in ISA LAT, i cannot delete 192.168.0.1 this IP, because if i delete it, client computer cannot go Internet, and cannot recognise the DNS. What other solution to fix that FTP problem???
(in reply to erica_zhu)
RE: ftp with -a DOS command - 21.Jun.2002 11:59:00 AM
erica_zhu
any one can help??
RE: ftp with -a DOS command - 21.Jun.2002 10:56:00 PM
Hi erica,
your ISA configuration seems not right to me. The LAT should *only* contain the internal LAN, surely not the external one!
I suppose your configuration is something like:
internal LAN --- ISA --- Symantec --- Internet
This is perfectly possible. First you"ll have to fix your basic ISA setup. Check out http://www.isaserver.org/pages/learning_zone.asp .
RE: ftp with -a DOS command - 22.Jun.2002 3:33:00 AM
erica_zhu
hi stefaan,
what will be wrong of my isa setting, i can get it done in another ISA that i setting, i exclude the external LAT in another ISA, it works. but for this ISA, once i delete the external LAT, the ISA server itself and the client computers cannot go to Internet, and the DNS also not work. What i might be mistaken in the isa setting??
RE: ftp with -a DOS command - 22.Jun.2002 7:43:00 AM
erica_zhu
hi, i have delete the external address for LAT in ISA, everything work fine in the LAN, clinet computers can access Internet and FTP, no problem in outgoing traffic. BUT from outside cannot access the LAN, i cannot use terminal service outside, cannot access the local web site. what will be the problem??? any body can help????
RE: ftp with -a DOS command - 22.Jun.2002 9:05:00 AM
erica_zhu
anyone pls help??? anyone can tell me why??
RE: ftp with -a DOS command - 22.Jun.2002 5:22:00 PM
Hi erica,
in order to give external users access to internal resources, you need to web or server publish those resources. For more info, check out the ISA Help file and http://www.isaserver.org/pages/learning_zone.asp .
BTW --- I highly recommed Tom's book http://www.amazon.com/exec/obidos/ASIN/1928994296/isaserver/ . It is a must buy and read! [Big Grin]
RE: ftp with -a DOS command - 4.Jul.2002 5:54:00 PM
Hi Stefaan,
Thanks for recommending the book!
[Big Grin]
RE: ftp with -a DOS command - 7.Jul.2002 5:09:00 PM
lemonwater925
under your advanced settings uncheck enable folder view for FTP sites and give that a try.
