ISA server and IRC
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> ISA server and IRC Page: [1]
ISA server and IRC - 4.Jul.2002 1:47:00 PM
NeoYoshi
I don't through out with ISAserveur and irc ?
Why ?
I make a rules IRC with outbound and any access; but don't run ?
Perhaps in mirc, i do to make a configuration ?
It's same for access with a webpage-chat !
Help me please "[Smile]"
RE: ISA server and IRC - 9.Jul.2002 8:35:00 AM
zzz343
Are you using firewall client or securenat?
if you are using securenat you need to create packet filter or protocol rule for IRC tcp/ouond/6667.
If you are firewall client, you don't need to create any protocol. FWC will dynamically open the reuired protocl.
(in reply to NeoYoshi)
RE: ISA server and IRC - 11.Jul.2002 9:16:00 AM
NeoYoshi
THanks for the answer [Smile]
I am a firewall secure [Smile] My rules is create to outbound, but i don't go to through with mirc or another application to go out with port 6667 ?
For example: To the forum japancar.net, i want to go on Chat web client but i cannot to connect ?
Why ?
Help me !
THANKS
RE: ISA server and IRC - 11.Jul.2002 9:22:00 AM
zzz343
goto extensions / http filters / and select 'send direct to requested web server'.
Now in explorer options, remove tick from 'use a proxy server'. and then check. I hope it will work. For some chat servers you need to create packet filter or protocol rule like volano chat server.
[Big Grin]
RE: ISA server and IRC - 7.Jan.2003 5:33:00 AM
weekapaug
I enabled the IRC definition and mIRC (IRC) works fine except DCC doesn't work. It works of course when I allow all traffic but it doesn't. It worked before I rebuilt the ISA server. I backed up the previous settings before I formatted but of course when I tried to restore everything on the new build it said the configuration didn't match..go figure.. anyways, any help getting DCC to work would be helpful. Thanks.
Gary
RE: ISA server and IRC - 8.Jan.2003 9:25:00 AM
nsidir
I have the same problem...I can get esatblished any DCC transfer. How can I fix this?
RE: ISA server and IRC - 9.Jan.2003 10:51:00 PM
HJB417
to make DCC and IDENT for for mirc, add the following the the Firewall CLient Application Servers on the ISA server and then update the ISA Clients
[mirc32]
NameResolutionForLocalHost=P
ServerBindTcpPorts=113,1025-5000
[mirc]
RE: ISA server and IRC - 9.Jan.2003 11:28:00 PM
Hi HJB,
You da man!
