mIRC and DCC gets
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> mIRC and DCC gets Page: [1]
mIRC and DCC gets - 7.Jan.2003 2:15:00 PM
nsidir
I have the following problem:
When I use mIRC I can connect to any IRC server but when I try to make a DCC connection to get a file, I cant establish a connection.
In ISA Server I have created a protocol definition (TCP, outbound) allowing a certain port (refferenced as ???? from now on), I have created a protocol rule allowing that protocol and I have created also 2 packet filters (one for outbound traffic, one for inbound traffic).
I have install Firewall client in my PC.
In Client Configuration, Application Settings I have added ("mirc, localtcpbind, ????,6667", "mirc, remotetcpbind, ????,6667", "mirc, localudpbind, ????,6667", mirc, remoteudpbind, ????,6667".
After all this things I still can't establish a DCC connection... "[Confused]"
What am I doing wrong?
Thanx in advance!
RE: mIRC and DCC gets - 13.Jan.2003 9:14:00 AM
HJB417
this is all u need for DCC SEND, DCC GET, and IDENT when using mirc
[mirc32]
ServerBindTcpPorts=113,1025-5000
NameResolutionForLocalHost=P
[mirc]
(in reply to nsidir)
RE: mIRC and DCC gets - 13.Jan.2003 4:17:00 PM
nsidir
Although I tried what HJB417 told me to set in application settings in FW Client Configuration I stil can establish a DCC connection with mirc.
Problem remains... [Confused]
RE: mIRC and DCC gets - 14.Jan.2003 2:28:00 AM
HJB417
did you restart the firewall service?
did you try reinstalling the firewall client [though you shouldn't have to].
RE: mIRC and DCC gets - 14.Jan.2003 9:30:00 AM
nsidir
I have tried both updating the FW client and reinstalling it. Nothing. The question is: is only those application settings in FW client configuration the only ones needed or should I make a protocol definition with primiry connection TCP outbound 6667 and a secondary (UDP or TCP I dont know, ports 1025-5000) and then a protocol rule allowing it. I know it maybe annoying answering the same things but its been one month that i 've been trying to enable DCC transfers and nothing has been done.
Thanx anyway. [Wink]
RE: mIRC and DCC gets - 15.Jan.2003 3:46:00 AM
HJB417
I never had to add or modify protocol rule definitions. I did create an "All Access" protocol rule. You don't need a protocol rule for mirc because the firewall client can handle the connecting to the IRC server. Also, how did you enter the firewall client settings? Did you use the MMC or did u do something else like manually edit the mspclnt.ini file?
RE: mIRC and DCC gets - 15.Jan.2003 9:56:00 AM
nsidir
The FW client application settings were accessed through the MMC. In the Application Settings window I added the parameters you said, then I restarted the ISA server service, updated the FW client but nothing happend.
Should I retry editing the ini file manualy?
RE: mIRC and DCC gets - 15.Jan.2003 8:58:00 PM
HJB417
na, you shouldn't need to. Next time your on irc join a gamesnet or efnet server and msg me. I gotta see this for myself. My name is bastardizer on gamesnet and |Artanis| on efnet.
RE: mIRC and DCC gets - 6.Mar.2003 2:08:00 AM
WonderCrew
Was a resolve found for this problem because it sounds exactly the same as the problem that I am having.
